Refrigerators
Problem for Refrigerators
Generic problem for all Refrigerators
Kenmore fridge
By missyblues on Nov 27, 2007
purchased in 6/2006
freezer over flows to fridge side
fridge not cool enough
tried the temp buttons and nothing
Solution #1
posted on Nov 27, 2007
Not Rated)
Cerfer39
Rank: Guru
Rating: 87%, 1171 votes
Hi Missy Blues,
Your Fridge is in major need of defrosting. This will require you to clear the goods out of your Freezer temporarily. I believe you have a Problem with a component is the Auto defrost Circuit. First of all we need to get the frost out. Once you have the Freezer cleared, Turn the freezer off. Place a Hair dryer in the door of the freezer with its nozzle pointing at the back of the freezer compartment. Run the Hairdryer for a couple of hours blowing into the freezer with the freezer door crak open slightly. This should melt all the frist in your freezer. You will probably need some towels to help soak up water. Once the Freezer is defrosted. Remove the panel inside back of the freezer. The section under the icemaker. You will see a radiator coil. Disconnect power to the fridge. At the bottom of this Radiator coil you will see a device bolted to the bottom of the coil with wires going to both ends. This is your Defrost Heater. REmove it. It is a glass tube with a spring looking heater inside. If the spring parts is burned apart, the heater is bad, and that is your problem. Put all the goods back in your freezer, and turn it on. Go to Sears Parts store and get another defrost heater. You will need the model number of your Fridge. Good Luck
Popular Solutions for Refrigerators
Questions and Unsolved Problems for Refrigerators
Answer
I am thinking of buying a used 2005 GE side by side fridge model GSS25XSRCSS. Any experience good... (More)
Answer
the samsung four door quattro refrigerator
Answer
Maytag refrig stays TOO COLD...15 degrees...icemaker fails to work, possibly keeps tray warmer from... (More)
Answer
why my refrig will notstay cold . the motor is running,but it is not freezing
Answer
water won't come out of the dispenser. I Checked to the door and the water works to the door, but... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
