Question about Vehicle Parts & Accessories
Valet mod.552t must have hit a button by mistake now i get no confirm lights when locking or un locking owned 20 yrs. never happened before....tks
Dei product how to fix
SOURCE:
mkv0525
  • 358 Answers
SOURCE: 1994 Lexus LS 400 Valet Lock Stuck - Can't Open Trunk
you have to have a main key. you may be able to remove the panel and release that way. under dash. pull cable.
Posted on May 21, 2009
logosc75
  • 625 Answers
SOURCE: My DEI Valet system will not operate the door
You failed to mention the year/make/model of the vehicle so, I will assume that there existed some sort of door lock/unlock/alarm disarm bypass module in your vehicle that is no longer functioning. There is no simpler fix then either resetting the module or, remove and replace it.
Posted on Sep 30, 2010
SOURCE: i have a 94 grand prix with a dei remote start not
It sounds like there's no power going to the starter wire. Try and locate the brain under the dash for the remote start. It should be black and about twice the size of a deck of cards with a few harnesses hanging out of it. Usually it is zip-tied to a wire harness or bracket to keep it secure and from falling down onto your feet. There should be several wires much larger than the others, and you should see fuseholders on the 2 red ones. Usually one of the fuses is used solely for the starter. Check both fuses on these larger wires. Should be 30 amp green ones if I remember right. Also, while you have the brain accessible, write down the model number on the brain itself to help you in the future. Most DEI remotes can be used for almost any DEI/Viper/Your Valet system, so it's really hard to tell what you have just by looking at the remote. If the fuses are fine, you may need to take it to a shop (anyone that sells Viper and such). If you have a chip in your ignition key, it may also be the security bypass module that gets installed with the remote start. You will only have this bypass module if you have the little chip in your ignition key. Hope this helps, good luck.
Chad
Posted on Dec 08, 2010
  • 237 Answers
SOURCE: 2005 Nissan Maxima SL, trunk
does it work when you press release on key fob?if so remove the glove box and make sure someone performing work previously in that area didnt foget to plug it in.
Posted on Feb 01, 2011
  • 1140 Answers
SOURCE: Oven lights do not turn off when closing door or hitting on/off button. What may be the issue? What can I check on my own before calling a repair tech? Tks!
The on/off switch is defective.
Posted on Sep 23, 2015
How to program a remote control viper 5900 for a chevy Tahoe
Should be a switch for overriding the alarm under the drivers side dash. Two wires going to it (grey black) with a push button on the end if it. Have the driver door open and turn the ignition to on not running,,,, push the valet button and let go and then push and hold valet button........ Hit lock on the transmitter one time while still holding the valet button down. You should get a chirp for entering program and then when you lock on the remote it will make another chirp. But the chirp will sound awkward. Let go of valet and and turn truck off. And test remote. If that's doesn't work you may need to follow all the same steps but instead if press once and press and hold you will need to push 8 times and hold on the 9th and hit lock on the remote. I'm pretty sure the it's sequence is for alarm security and 8 steps is for remote start only models. Food for though if my mind is working backwards. Best off luck. All else fails I'm sure a shop will do for about 20$
Oct 28, 2013 | 5900 SST 2-Way Security System / Remote...
Hello I have a Mazda Tribute 2002 model that the remote will not work on. i bought a new remote with the same number on it 1L87T-15K601-AA and I cant program it I have done the turn key 8 times to get door...
These are the correct instructions.
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. Door
locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle to confirm
programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will cycle again to
confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Jun 22, 2012 | Cars & Trucks
How to reprogram Python 4Button Remote 474P ?
I had the exact same thing happen with my 4-button 474p remote. WITHOUT REMOTE START the correct sequence is:
1. Enter car - Leave door open.
2. Turn key to "on" position.
3. Within 5 (five) seconds press the Valet button 7 times then hold down. (Programs to channel 7)
4. Watch alarm light - It should now flash 7 times.
5. While still holding down the Valet button - Press the "lock" button on the remote and release. Should get a "chirp"
6. Now release and repress the Valet button once, holding down. You'll get the "chirp". Release Valet button.
7. Turn key "off". Exit vehicle and test remote. All 4 buttons should now work.
Mar 09, 2012 | 4Button Remote 474P
My 2002 Alero will not turn over
Make sure the valet parking lock in the glove box is not locked. You'll need the master or driver #1 key. If VP is not locked and this happens use the master key and manually lock and then unlock the driver door then try starting the car. And also you have a working remote key unit when this this happens, step back out of the car. if you have passengers have them exit too. Hit the lock bottom wait a couple of seconds hit the unlock button just once. Only you the driver get into the car place key in ignition turn it over Note: if it dings your good if nothing you'll need to keep locking and unlocking until the security light dings.
Nov 08, 2011 | 2002 Oldsmobile Alero
Viper remote start system just installed. When I use the remote to lock the car--there is no longer a chirp noise that confirms I hit the lock key. Thanks, Mary
I don't know which remote starter you have, but I have a Viper 5101. To fix this problem, I started the ignition, then turned it off, leaving the key in the ignition. I pushed the Valet button (it has a blinking blue light, mine is near my rear view mirror) and held it. Then, I pushed it 3 times, then held it down a 4th time. Then, I pressed the lock button once. I pushed the Valet button again to take it out of programming mode, and it worked! I got this sequence of steps from the installation manual online: http://www.scribd.com/doc/45065156/Installation-Viper-5101 Hope that helps!
May 12, 2011 | Remote Start System
I had to replace the battery in my car and now my remote will not do anything lock or unlock the doors start the vehicle or pop the trunk what do i do?
Reprogram the remote: turn ignition on, press and release valet switch one time. Press and hold valet switch. While holding valet switch, press lock button on remote. The alarm should chirp to confirm entry into the programming mode (when you press and hold the valet button) and when you press the lock button. Turn ignition off. Test remote.
Jan 24, 2011 | 791XV The 791XV is a 2-way Security and...
How do I program a Viper 473 V Replacement Remote, to my 2004 Hyundai Santa Fe?
Set lock/unlock button
· open drivers door
· turn key to ON position
· press valet switch 1 time
· press valet switch again and hold
· when alarm chirps press lock/unlock on remote
· release valet switch
· turn key off
Oct 05, 2009 | Viper Security and Remote Start System...
Does not cherp
Is your perhaps alarm in "valet mode"? I've got a Checkmate on my Honda, and I can turn valet mode on/off by putting the key to Accessory, then pushing the black button under the left of the steering wheel. The alarm chirps when you switch the mode.
May 23, 2009 | 2000 Buick LeSabre
I cant disarm my alarm
Get inside the car, turn the key to the on position, the alarm is going to sound so do not panic when the alarm sounds press the valet button one time and the alarm should stop. To place the alarm in valet mode cycle the key with the door open on then off then press the valet button one time and the alarm should go into valet mode meaning the alarm light will be on steady.
Feb 03, 2009 | Viper Security and Remote Start System...
Fuse box location
I have a '99 Deville. Had the same problem. In the glove box, there are two toggles for Traction Control and Valet. Toggle the Valet one and try the remote on your key or the buttons in your dash.
For mine, someone had engaged the Valet to "ON" and locked out the remote trunk and fuel door.
Sep 21, 2008 | 2000 Cadillac DeVille
Vehicle Parts & Accessories Logo
42 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
