Question about Jabra Radio Communications
My jabra bt2027 light is blue -- i have been reading that if it is charging the light should be red or green. Mine is blue. So how do i know if it is already charged
SOURCE:
SOURCE: jabra bt160
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2)
For optimal performance, wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight. In general, you will get better performance when
there are no obstructions between your headset and your mobile phone. (See fig. 5)
Answer a call
Tap the answer/end button on your headset to answer a call
End a call
Tap the answer/end button to end an active call
Reject a call (Dependent on your phone supporting this feature)
Press the answer/end button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (subject to phone
settings) automatically transfer to your headset
Activate voice dialing (Dependent on your phone supporting this feature)
Tap the answer/end button. For best results, record the voice-dialing tag through
your headset. Please consult your phone’s user manual for more information about
using this feature
Redial last number (Dependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+ or –) to adjust the volume (See fig. 1)
5 How to...
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode
Make sure that the headset is on.
Press the answer/end button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT160
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’
‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’
or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 4)
3 Pair it with your phone
English
2 Turn on your headset
Press the answer/end button to turn on your headset
Press and hold the answer/end button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
Posted on Jun 16, 2008
SOURCE: new jabra 350 can't be charged
right out of the box i had the light flicker on me too. if you don't have warranty or receipt like i did try this. i'm not responsible if it doesn't work after!
peel off the blue part of plastic that has jabra on it. take a screwdriver and unscrew the star screws. take the cover off. using some wires, briefly connect a battery (i used a wireless drill battery) to the leads of the bluetooth battery. you'll see a spark.
now my thing is charging for the first time
Posted on Jan 02, 2009
  • 629 Answers
SOURCE: Battery Charge light flashing 4 red one green Dell Inspiron 9200
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
Posted on Mar 16, 2009
SOURCE: Unit will not charge. Red light just flashes
I had a similar problem with two new units.
Pressing the pairingbutton and de on/off button at the same time, while the unit was on the charger, solved the problem for one of the two.
The other still wouldn't charge.
On this one I had to do the same, but for a longer period (2 minutes at least). This solved the problem on this one too.
Posted on Jul 04, 2009
casouzaj
  • 1118 Answers
SOURCE: jabra appears to be working with turning on and
Your speakerphone must be in pairing mode, prior to trying to pair it with your phone. If it has never been paired before, just by turning it on it would enter that mode. It is indicated by the icon rapidly flashing, and an audio announcent like 'pairing mode'. If your speakerphone has been paired before, you must force it to enter the pairing mode. To do it, after turning it on, press and hold the answer/end button for some 5 seconds, until that same announcement is heard, and the icon rapid flash is noticed. Anyway, after it is in pairing mode, make your phone's bluetooth application search for new devices. After a while, your spearkerphone should appear on-screen. Select it and make the application connect to it. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your speakerphone will enter stand-by mode, and you should also see some indication on your phone.
By the way, if your speakerphone's user manual happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out soon.
Regards, Carlos
Posted on Sep 17, 2010
Jabra sport will not charge
Same problem did you call the 800 number?
Dec 09, 2011 | Jabra Radio Communications
Jabra red light of death
seeing the red light tells you that the jabra isn't fried or shorted and that there is life but there is a problem, the red light isn't blue when it should be. so have you read the directions your ear piece came with when you first bought it?... hold the on button until you see the blue light stays on.(blue light will flash fast then slow then come to a complete stop and stay on) once blue light stays on that should mean you can now find the ear piece on your cell phone to link up. if problem still isn't fixed then you might as well buy a new one.
Aug 04, 2009 | Jabra BT350 Bluetooth Headset Headset
How do I know when Jabra BT4051 fully charged?
I charged mine until the light went off
Jul 01, 2009 | Jabra Cell Phones
Jabra bt2020 will not charge/function
I don't know how long you have had the headset but it sounds like it isn't holding a charge.  Contact Jabra to find out what the warranty is on the headset.
Nov 12, 2008 | Jabra BT2020 Bluetooth Headset
Getting bluetooth to come on
it seems to me that you have not charged the unit because i had to do that when i got mine ...i had to charge it for 2 hour
Jan 03, 2008 | Jabra BT125 Headset
Steady Red Light
From the sounds of this.. It's all due to bad keying of the polarized charging plug. The solid red light PROBABLY means you're battery is pretty darn dead. It'll need a new battery(not worth the cost imho. get a new jabra, and be happy once again) At a certain low voltage, the red light starts blinking. when it drops below the preset threshold, it will shut off completely. If it sits too long at this discharged rate, the battry WILL self-terminate. If the voltage drops below a certain level, it's ruined. Also note, most Li-ion cells will only last a few years. 2-3 years of "full power" is usual. Mine's 2 years old(steady usage), and showing signs of it's age.
"My red light won't go off even though I charged it all night.
Also, a small piece of plastic came off the charge opening. I don't know if this is will pose a problem to the use of the Jabra BT150."
This is probably the most telling bit of information. It means you DID plug the charger in upside down. It will NEVER charge in that configuration, as it is supplying power to the completely wrong pins. If the battery was good to start with, it shouldn't hurt the headset, but never know. I have accidentily plugged it in backwards for a couple min before noticing, with no ill efect, but YMMV.
"Doesn't anyone from the Jabra manufacturer check this site?"
NO (especially not for discontinued products)
Oct 05, 2007 | Jabra BT150 Wireless Headset
Radio Communications Logo
41 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
