I have a whirlpool refrigerator model mfd2560hew. It side by side refrigerator doors and bottom freezer. It has an ice maker and a filtered water outlet. I am not getting any water to either area. Any ideas.
I have checked the water supply and it is on. There is also a hum when I press the water dispenser button, but no water through the dispenser or the ice maker.I have checked the water supply and it is on. There is also a hum when I press the water dispenser button, but no water through the dispenser or the ice maker.
You can't post conmments that contain an email address.
Change the=> 67006531 Water Inlet Valve I believe the side of your 67006531 Water Inlet Valve that controls water flow to the ice maker has weakened and cannot open properly. Replace the water valves and I believe the ice maker will work fine, Sea Breeze
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sometimes filters have issues like this even being new , it is located at the bottom kickplate [round] , pick up a new filter -part number 4396841 - install the filter , dump remaining ice in bin out , purge the water through the new filter through water in door for a few minutes and you should be good.
Phil
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge? When have you last changed the water filter. Should be down below at the front grille! Try these tasks!
If the ice maker is not producing ice or not enough ice Refrigerator connected to a water supply and the supply shutoff valve turned on? Connect refrigerator to water supply and turn water shutoff valve fully open. • Kink in the water source line? A kink in the line can reduce water flow. Straighten the water source line. • Ice maker turned on? Make sure wire shutoff arm or switch (depending on model) is in the ON position. • New installation? Wait 24 hours after ice maker installation for ice production to begin. Wait 72 hours for full ice production. • Freezer door closed completely? Firmly close the freezer compartment door. If the freezer compartment door will not close all the way, see "The doors will not close completely." • Large amount of ice recently removed? Allow 24 hours for ice maker to produce more ice. • Ice cube jammed in the ice maker ejector arm? Remove ice from the ejector arm with a plastic utensil. • Water filter installed on the refrigerator? Remove filter and operate ice maker. If ice volume improves, then the filter may be clogged or incorrectly installed. Replace filter or reinstall it correctly. • Reverse osmosis water filtration system connected to your cold water supply? This can decrease water pressure.
Let me know how it goes! Huuum Please remember to leave a rating!
the refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser. the valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
another thing that could cause it would be the temperatures in the freezer. the ice-maker will not call for water until it reaches under 15 degrees.
