Question about GE Dishwashers
I have a GE Potscrubber 900. I have water entering the dishwasher from the opening on the left side, but the water tower does not work. Can you help
  • 1,316 Answers
The main pump motor may not be working. If you cant hear it running, it may be jammed up or burnt out. If you can hear a loud humming noise, its possible its only jammed. You will have to remove the pump and see if any foreign matter has stuck in the pump impellor. If the pump is running, check the small outlet holes in the spray arms, they may be blocked.
Posted on Apr 10, 2019
SOURCE:
  • 114 Answers
SOURCE: ge potscrubber 640 dishwasher
You probably have a restricted water inlet valve. It is not allowing the proper rate of flow for the allotted time, therefore not giving enough water to create the proper velocity to reach the top rack.
Posted on Feb 19, 2008
SOURCE: GE potscrubber 700
upc leaks when dishwasher is emptying
Posted on Sep 03, 2008
rockitman187
  • 2559 Answers
SOURCE: Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Posted on Jan 11, 2009
SOURCE: GE POTSCRUBBER 1200 DISHWASHER
I have a Ge Potscrubber 1200. Fairly new I guess as I bought it with the house that I purchased 1 1/2 years ago. Sometimes it drains and sometimes it does not. Today there was two inches of water! About to remove the bottom panel. Sounds like the drain valve it blocked but not sure. Any thoughts?
Posted on May 06, 2009
localwonder
  • 6784 Answers
SOURCE: Potscrubber 900 Dishwasher won't drain
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Aug 27, 2009
GE Potscrubber 900 just runs and runs, dial just sits there
Hello Debbe,
Does the dishwasher fill with water, or is full and fails to drain?
Can you provide additional detail so that we may accurately troubleshoot? Also include the complete model number. It should be etched or stamped on a plate inside the door, or elsewhere on the washer.
Thank you!
Jan 30, 2018 | GE Dishwashers
Ge potscrubber 800
GE Potscubber 800
Issue: No water.
What works:
- Dishwasher appears to operate normally, just does not call water.
- Water valve works
Suspected:
- Float / float switch
Needed:
How to test float switch
Jun 01, 2013 | GE 24 in. GSD3400G Built-in Dishwasher
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
Burning smell coming from dishwasher caustic to nose. GE Potscrubber 900. Nothing on element upon inspection. Smell more at beginning of wash cycle or when using the pot scrubber button
Older GE's had problem with drain coils over heating
Remove the bottem front plate and the coil will be on the left side of the moter and activate when the drain cycles, check that
Apr 22, 2010 | GE 24 in. GSD2000Z Built-in Dishwasher
GE Potscrubber disher - water leaks out while filling
I would try removing the cover and make sure the float isn't sticking. On mine the float pushes on a rod that goes through the tub to a micro switch. When you hit it, it probably frees it up for a while. Hope that helps.
Jan 21, 2010 | GE Dishwashers
GE Potscrubber Quiet power1....horrible film left on dishes, especially plastic & tupperware
The film is usually due to hard water.
If you have hard water, you need to use gel or liquid detergent only. Try that and use smaller amounts.
Also, you can try flushing out the pipes by using a product called Dishwasher Magic, which is sold at OSH.
Best of luck,
Ned
Sep 18, 2009 | GE Dishwashers
I have a GE Potscrubber dishwasher that only hums, won't run
I have a portable that had the same problem. I called a repairman and he turned a fan blade on the motor. Mine is located on the right side about 12" in. It gets hung up when it is run often enough. If your problem is the same is mine all you have to do is turn the blade and it works like a charm. Hope this helps.
Feb 18, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
GE potscrubber 700
May 12, 2008 | GE Dishwashers
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Vitally Alcher
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
