Question about Microsoft Windows Vista Ultimate Edition
No startup On startup, after typing in password, it says "please wait". After 2min, it says "configuring updates". Startup repair then tries to fix the problem. Then my pc shuts down and the whole process starts again! I can't gain access to my computor. HELP!!!
Man i dont know.but im sure whatever osbourne is saying is not a feasible soln to the problem.any problem can be solved by doing that ..but der must be some measures to handle this ..so better visit the site ...
Posted on Nov 27, 2007
    Sergeant:
    Champion:
  • 306 Answers
While its booting tap the F8 key into safe mode, once in safemode run registry cleaners/spyware/virus cleaners. if that doesnt work formate drive and reinstall windows.
How to find out password for startup on gateway sx2110g desktop computer
It sounds like a Bios or Hard Drive password has been set. This does not happen by accident, start asking everybody with access to the computer.
Dec 31, 2016 | Gateway Computers & Internet
Canon 8600F will not install on W indows 7
1. Click Start.
2. Type MSCONFIG in the Start Search box and press Enter on the keyboard. If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
3. The System Configuration Utility will appear.
4. Make a note of which startup selection your computer is set on. If your startup selection is set to Normal, switch it to Selective Startup by placing the radio button dot next to Selective Startup.
5. Under Selective Startup, click to clear the Load Startup Items check box.
6. Click the Apply button.
7. Click on the Services tab at the top.
8. Place a check mark next to 'Hide all Microsoft Services'.
9. Click the Disable All button.
10. Click Apply.
11. Click the OK button.
12. Windows will prompt you to restart your computer; click Restart.
Once the system restarts, try reinstalling the drivers from Canon.
After you reinstall, it should work fine, it did on mine.
Then you go back into msconfig and reset your startup options to normal and reboot.
Jun 14, 2012 | Canon CanoScan 8600F
My dell laptop latitude c600 can not load up to the desktop, it only show DELL, www.dell.com, latitude c600 and bios revision A07. What is the problem?
try removing the battery from th back.wait for like 5 minutes then restart the computer.
you can also flash the BIOS.
else try pressing F8 at the startup if you can go yo the advance boot options.
go to repair my computer..select the language then select the username and password..then in system reco ery optios try startup repair or system restore.
else go to safe mode with networking...there in command prompt type sfc /scannow if you have vista or 7..else if you have the xp in advance boot menu try last know good configuration.
if none of the above is working..try ctrl+F11 at start up which will take you to recovery option..you can perform system recovery there...but it will delete all the data.
if the above step is not working try to use the windows repair with the oprating system cd.
insert the cd in to thr cd rom, restart the computer
press F12 at the startup it will give you the boot sequence then select the cd
and if none of the things are working contact dell..there might be a hardware issue
plese rate if you find this helpful..thanks
Aug 20, 2011 | Dell Computers & Internet
Open laptop and the screen wont go on
and if none of the things are working contact Gateway..there might be a hardware issue
Aug 20, 2011 | Gateway Computers & Internet
When i turn on my hp pavilion a1220 n . in about 45sec's a pop up comes up and reads EZ Dock int easy uistring config xml failed . what is it and how do i fix it please?
if you have xp computer follow this step: start/run/msconfig and hit enter. system configuration window will open then click on startup/disable all/apply/ok
restart te computer and issue will be fixed//
if you have vista computer- start/start search/type msconfig and hit enter.
if you have windows 7 computer- start/search programme and files type msconfig and hit enter.
May 12, 2011 | Computers & Internet
Hi i have 1841 router what is the default user name password for this i tryed with user name passowrd as cisco but is saying that no user cisco pls help me
  • Follow these steps in order to recover your password:
    1. Attach a terminal or PC with terminal emulation to the console port of the router.
      Use these terminal settings:
      • 9600 baud rate
      • No parity
      • 8 data bits
      • 1 stop bit
      • No flow control
    2. If you can access the router, type show version at the prompt, and record the configuration register setting.
      Note: The configuration register is usually set to 0x2102 or 0x102. If you can no longer access the router (because of a lost login or TACACS password), you can safely assume that your configuration register is set to 0x2102.
    3. Use the power switch in order to turn off the router, and then turn the router back on.
      Important Notes:
      • In order to simulate this step on a Cisco 6400, pull out and then plug in the Node Route Processor (NRP) or Node Switch Processor (NSP) card.
      • In order to simulate this step on a Cisco 6x00 with NI-2, pull out and then plug in the NI-2 card.
    4. Press Break on the terminal keyboard within 60 seconds of power up in order to put the router into ROMMON.
      If the break sequence does not work, refer to Standard Break Key Sequence Combinations During Password Recovery for other key combinations.
    5. Type confreg 0x2142 at the rommon 1> prompt in order to boot from Flash.
      This step bypasses the startup configuration where the passwords are stored.
    6. Type reset at the rommon 2> prompt.
      The router reboots, but ignores the saved configuration.
    7. Type no after each setup question, or press Ctrl-C in order to skip the initial setup procedure.
    8. Type enable at the Router> prompt.
      You are in enable mode and should see the Router# prompt.
    9. Type configure memory or copy startup-config running-config in order to copy the nonvolatile RAM (NVRAM) into memory.
      Important: Do not type copy running-config startup-config or write. These commands erase your startup configuration.
    10. Type show running-config.
      The show running-config command shows the configuration of the router. In this configuration, the shutdown command appears under all interfaces, which indicates all interfaces are currently shut down. In addition, the passwords (enable password, enable secret, vty, console passwords) are in either an encrypted or unencrypted format. You can reuse unencrypted passwords. You must change encrypted passwords to a new password.
    11. Type configure terminal.
      The hostname(config)# prompt appears.
    12. Type enable secret password> in order to change the enable secret password. For example:
      hostname(config)#enable secret cisco
    13. Issue the no shutdown command on every interface that you use.
      If you issue a show ip interface brief command in privilege EXEC mode, every interface that you want to use should display up up. For example:
      Router#show ip interface brief
    14. Type config-register configuration_register_setting>. Where configuration_register_setting is either the value you recorded in step 2 or0x2102 . For example:
      hostname(config)#config-register 0x2102
    15. Press Ctrl-z or end in order to leave the configuration mode.
      The hostname# prompt appears.
    16. Type write memory or copy running-config startup-config in order to commit the changes.
Jul 02, 2010 | Cisco (1841) Router (cisco1841)
Configuring updates dont stop
I'll assume last known good configuration didn't work, if you press f8 and choose disable automatic restart on failure, you should see the blue screen of death with more info, when you reboot the next time,(you may have to hold in power button for 5 secs), press f8 and see if Repair my computer is listed on the Microsoft Startup menu, if not, insert a windows vista disk and restart,booting to the cd(should happen automatically, but look for a prompt to press a key) choose your language, then choose repair my computer, choose the windows installation, and you can try to use system restore to go back before the uodates were installed and updated, then disable automatic updating so it doesn't repeat.
Mar 26, 2009 | Acer Aspire 5315 Notebook
Reboot and select proper boot device or insert boot media
Try inserting your Windows CDROM at startup and look for press any key to boot from cd.
Wait 'til " Welcome to Setup" occurs and press R for repair.
Type Administrator password or just click enter after choosing
(most likely) 1. At windows prompt, type fixboot and after self
repair type exit.
The system is likely encountering a critical error and
theautomatically restart option has been selected in
the startup andrecovery options.
Right click on My Computer and select
Properties/Advanced Tab/Startup and
Recovery/Settings Button.
Under System Failure, uncheck the Automatically Restart
option. Thiswill allow the error to be displayed when
the problem is encountered.
You need to perform some troubleshooting steps to
try and locate exactly where the problem is coming
from.
Good Luck...Nate P.
Jan 11, 2009 | Computers & Internet
Turning on my computer
if you are using windows operating system go to star menu and run , in that run program type msconfig and press ener then go to startup tab select and unselect the program what you like to run on the startup and apply and save the settings and restart the computer after when you restart the window comes please select don't show this message again and close these are first step you want to stop the process when startup please check it.
Apr 28, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
Microsoft Windows Vista Ultimate Edition Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
