Whirlwind -Air Cooler with Heater and Humidifier, FH-778 Air Conditioner
Problem for Whirlwind -Air Cooler with Heater and Humidifier, FH-778...
Leaking central a/c unit
By khyatt77 on Aug 06, 2009
Water is leaking onto the basement floor from the unit causing mold. Sometimes this happens when the filter is old or displaced, but this is not the case now. I don't know where to start. Help!
Best Solution
posted on Aug 06, 2009
Helpful)
VtToolMan
Rank: Guru
Rating: 97%, 682 votes
All central A/C units have a condensate drain line that comes from just under the evaporator in the Main air supply plenum.
You may have a blockage in that drain line and will have to remove the pipe to clear the obstruction. Try flushing the drain pipe with warm water until it flows easily from the top to the end.
You might have a gravity drain that goes into a floor drain or a french drain along the basement walls. The other typical drain installation is a condensate pump that the water drains into and when the float in the tank is lifted, a small pump turns on and pumps the water (condensate) out of the house either thru a drain hose thru the wall, or into a drain in the basement, etc.
Check the entire drain line and anything connected to it for any possible obstructions and/or blockage.
If you have any other questions once you take a look at your installation, just add a comment and I'll check back within a day to provide more info, based on your input.
I hope you found this very helpful and best regards!
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Whirlwind -Air Cooler with
Questions and Unsolved Problems for Whirlwind -Air Cooler with
Do you recommend Whirlwind -Air Cooler with Heater and Humidifier, FH-778 Air Conditioner?
Answer
Answer
my evaporative cooler blows warm to hot air when the weather heats up outside.as the outside... (More)
Answer
Need to know where's the 2 hoses for the heater core by the fire wall is for a 99 ford F-150 4.6L... (More)
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , NY
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
