Question about Mitsubishi Televison & Video
My Mitsubishi tv comes on but shuts right down within a few seconds. What could be the problem?
SOURCE:
DrGreeley
  • 3 Answers
SOURCE: mitsubishi WD-65731
Here is a link to what models have a recall for a faulty sensor... extended warranty on that part preplaceable for free by MDEA.
http://www.mitsubishi-tv.com/j/i/18312/Warranties.html?mid=125121
Posted on Dec 27, 2007
SOURCE: RCA L32WD12 32in. HGTV LCD Television
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
Posted on Aug 01, 2008
  • 179 Answers
SOURCE: Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Posted on Nov 17, 2008
rob52078
  • 40 Answers
SOURCE: When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Posted on Mar 13, 2009
  • 36 Answers
SOURCE: TV powers up initially, but shuts down within seconds.
These TV's are somewhat sensitive to internal heat. It appears your sensor has triggered an overheat. This doesnt mean you still have the heat issue, it just saying it needs to be replaced or reset, either way it is not something you can do in your home. Taking it to your local authorized shop will ensure proper repairs, about $90 worth.
Posted on Jul 24, 2009
Power Problems
Try leaving it unplugged overnight. It is possible it needs to discharge. If that doesn't work, I'd say you either have a bad switch, or a bad power supply. Hopefully the switch, because that's much easier to fix. Can you bridge the switch connectors with a wire? If it doesn't come on and stay on when you do that, it's a power supply issue (and not nearly as simple to fix).
Sep 03, 2007 | Mitsubishi VS-55707 TV
Replaced bulb but tv comes only comes on for about 10 to 15 seconds then shuts down and red light flashes
It sounds like you have a bad ballast board, or possibly the power supply going to the ballast bulb. I'm afraid that if you do not have the repair experience on solid state TV sets, you will need to contact and authorized Mitsubishi repair center. Good Luck
Jul 09, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
