Home | Whirlpool | RBS305PDS Electric Single Oven | How do i clean the gla...
Whirlpool RBS305PDS Electric Single Oven
Problem for Whirlpool RBS305PDS Electric Single Oven
How do i clean the glass window
By lukumonladip on Aug 06, 2009
how do i clean the glass window, i have grease stains on glass window.
i know soap detergent will not be enough... what do recomended??
Comments:
Aug 12, 2009
- Thanks for the help,however can anyone recomend another product other than simple green as it hard locate this product
Best Solution
posted on Aug 06, 2009
Helpful)
VtToolMan
Rank: Guru  Whirlpool Expert
Rating: 97%, 578 votes
I've found that a couple of cleaners will work.
You can try Simple Green full strength as it doesn't have any nasty fumes and cuts grease really well.
The other is sudsy ammonia, but I personally can't stand the odor when using this.
Another helpful tip is to warm the oven to about 200 degrees before you clean the glass, as that will help soften the gunk (that's a technical term!) and make cleaning it easier. Just turn the oven off and let it cool for about 5 minutes before you start cleaning the glass with the Simple Green (or the ammonia ugh!)
Now clean away with a decent sponge and paper towels.
Hope you found this very helpful and best regards!
Comments:
Aug 18, 2009
- OK, you can use a strong mixture of soapy ammonia and warm water (3/4 ammonia to 1/4 water) and apply it with a sponge and allow it to soak into the gunk. Keep working at it until you have removed the buildup, it will take some work, but it will disolve the gunk a little at a time.
Keep rinsing the sponge in clean water, not the mixture, and you'll get it cleaned up.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Helpful)
projdoc
Rank: Guru
Rating: 94%, 598 votes
simple green. it's non-toxic and biodegradable, so it's ok to use around food, and it works graet on heavy grease. but if all else fails, use easy-off oven cleaner.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Whirlpool RBS305PDS Electric
Questions and Unsolved Problems for Whirlpool RBS305PDS Electric
Do you recommend Whirlpool RBS305PDS Electric Single Oven?
Answer
Answer
my dimensions to my wall oven are depth 23 height 32 width 29 3/4 need to replace electric single... (More)
Answer
My double oven display stopped working, and now the ovens themselves won't even work. AFter a week... (More)
Answer
read out blank,when you turn on power just beeps
Answer
I hate my accubake oven. It has never held a oven temp for more then five minutes. Tech has been out... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool RBS305PDS Electric...:
Top Oven Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Oven Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
