Question about HP 1230 Plain Paper Inkjet Fax
Help me how do you replace a cartridge?
  • HP Master
  • 1,113 Answers
Turn on the power to the unit and open the cartridge access cover. The cartridges will move to the left allowing them to be accessed
LINK to manual
Posted on Nov 27, 2007
Need to replace cartridge on hansgrohe talis high arc faucet
The cartridge should come with instructions on replacement. The part number for the cartridge is 92730000. It is available through your local dealer or online dealer. If you need further help with obtaining the cartridge or installation feel free to give me a call at Hansgrohe. 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. I'll be happy to help.
Oct 04, 2012 | Hansgrohe 32070821 Talis S Single-Hole...
Faded printing issues with Brother MFC-9320
Try cleaning the corona wire on each toner cartridge. This may help solve your solution.
If this does not help try another thing.
Try and replace the toner cartridge. Maybe your toner cartridge needs to be replaced. Usualy when printed images are light or pale a toner cartridge replacement is recommended.
To see how to replace your toner cartridges check here
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
Hi, i want to know when it gives a error code 5200 what's wrong with it?please help
What brand of printer?
The general reasons are:
Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead)
Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead)
Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall
Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall
Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall
Which would mean the print head needs to be either fixed or replaced.
Apr 19, 2011 | Office Equipment & Supplies
How to replace ink cartridge
I hope you already got your cartridge replaced. If not, here's a link to the Lexmark website on How to Install the Cartridges in the Lexmark X5150. This also applies on replacing cartridges. Follow the instructions.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source. Hope this helps.
Jun 11, 2010 | Lexmark X5150 All-In-One InkJet Printer
Ink out. Press the OK button to replace the cartridge. So I do and I get, Open the scanner unit, replace the appropriate ink cartridges and Close the scanner unit. This after I filled the ink cartridges.
Here are a couple of sites that will help you replace your cartridges.
Documents & Manuals
Replacing Ink Cartridge
Precautions on Ink Cartridge Replacement
Hope this is of some help. Bud
Mar 30, 2010 | Epson RX620 All-In-One InkJet Photo...
Hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
No cartridge prompt
try to clean contacts on cartridge and print head with alcohol, if it doesn't help, try to put back your old empty cartridge, if it will prompt only for that new cartridg, you bought, than the new cartridge is probably broken, replace it
Jul 10, 2009 | Brother Multi-Function Center MFC-240C...
My smartbase mpc200 printer displays wrong cartridge,
ive replaced the cartridge like for like and ended up with wrong cartridge on the display panel. any1 help?
Feb 12, 2009 | Canon Office Equipment & Supplies
Our xerox M118 showing an error"replace drum cartridge'can any one help me?Plizzz
Hello, Your Xerox has two cartridges - one is the drum cartridge and the other is a toner cartridge. Please check the following I've researched from your user guide:
Replacing the Drum Cartridge
The drum cartridge is a customer replaceable unit. After approximately 55,000 copies/
prints, the machine will display a warning message before the drum reaches the end of
life. Order a replacement cartridge now to insure continuous operation.
Country Part Number for the drum cartridge replacement
All countries 13R589
Removing the Old Drum Cartridge
1. Pull the front cover towards you to open it.
2. Open Tray 5 (bypass tray) if necessary, and then open Cover A while lifting up
the release lever.
3. Lift up the colored lever, and slide the drum cartridge out until you can lift the
handle on top of the cartridge.
4. Hold the handle and remove the cartridge from the machine.
NOTE: When replacing the drum cartridge, make sure that the new cartridge is the
correct one specified for the machine.
Recycling the Drum Cartridge
The drum cartridge is designed to be re-manufactured. To recycle used drum
cartridges, return them to Xerox in the original packaging. Return labels are included
with each new cartridge.
Inserting the New Drum Cartridge
1. Remove the new drum cartridge from the box.
2. Undo the sealing tape and carefully pull out in the direction of the arrow to
remove the black protective sheet from the cartridge.
3. Place the cartridge in position and, using the handle, slide it into the
machine until it clicks.
4. Pull out the cartridge tape completely without breaking it.
5. Push the cartridge again so that it is correctly placed.
6. Close Cover A until it latches and then close Tray 5 (bypass tray).
7. Close the front cover.
Hope this helps. Good luck.
Dec 11, 2008 | Xerox WorkCentre M118 Black and White...
HP 1230 Plain Paper Inkjet Fax Logo
215 people viewed this question
Ben Johnson
