Canon NP 6551 Black and White Copier
Problem for Canon NP 6551 Black and White Copier
Canon 6551, service mode *28*
By lmarkovitz on Aug 06, 2009
Canon 6551, service mode *28* DOES NOT WORK. Pressing the *, then a number from 1 to 6 then star again, gets you six different menus. None of them user-friendly just a bunch of numbers, counters, etc. I have error 005, need a new web, but I cleared the web counter, and it won't go away. I am concerned over whether or not the new web will make a difference or not, since clearing the counter didn't allow me to be up while we are waiting to get the new one.
Comments:
Aug 06, 2009
- When I press *4* with the paper clip in the hole, I don't get any kind of menu to choose error/clear, but messages come up and I can go from one message to the next with the arrow key. Only one says "Error 1 ---<-*Start", and there is no way to clear this message. I hit clear, or zero, or reset all with the button pressed in or not, and the only thing that happens is the screen goes back to the error message. There is Power Cycle option anywhere either.
I can access the counters by pressing *6* with the paper clip pressing the hole button, but there is no counter for 619. Just letters and single digit numbers. I just cleared them all, but nothing is changing the error screen.
My service guy is ordering new heat rollers and web and wires, but not a cleaning belt, which I guess we can add, but I'm concerned this reset is not going to work even with the new parts in as he has no clue how to reset this stuff.
Any further advice?
Aug 06, 2009
- Hitting *4* doesn't give me any menu. There is nowhere to choose error/clear or power cycle. If I hit *6* I can get to the counters and clear them but none says 619. I just cleared them all and nothing helped. The service guy is ordering heat rollers/ wires, and web, and I can add cleaning belt, but I'm concerned that replacing the parts won't matter if we can't clear the errors. He doesn't know anything more than I do about accessing the modes, etc.
Solution #1
posted on Aug 06, 2009
Somewhat Helpful)
leecom72
Rank: Guru  Canon Expert
Rating: 89%, 2605 votes
For IR models press star * then press 2 & 8 keys at the same time and then press * again,
(if there are star (*), 2 or 8 key are not working, it's not possible to get in the setup mode.
for NP models there are a small push button inside the front door (press with a thin pin or straightened paperclip as there is a very small hole to push) to enter in the setup mode.
Regards.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
taran_2005
Rating: 88%, 1080 votes
It is necessary to replace Cleaning belt. The DC controller keeps count of the activation of the cleaning belt solenoid, and issues ‘E005’ when the count reaches 250,000. The count can be cleared by resetting the cleaning belt counter ‘619’ in service mode.
50% of the time, you can get it removed by following the below procedure :-
Open the front cover and on the right or left side of the inner front cover there is a small diameter hole that if you stick a paper clip into it will activate the service mode switch which will be denoted by a dollar sign on the control panel. From there push the additional functions key then 4 then the additional functions key again. From there go to error/clear and power cycle and it should be good to go as long as the web has been replaced. This is off the top of my head and it has been awhile so I hope I gave you the correct order.
If problem still persists, call Canon.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Was this helpful?
Yes
No
Popular Solutions for Canon NP 6551 Black and White
Questions and Unsolved Problems for Canon NP 6551 Black and White
Do you recommend Canon NP 6551 Black and White Copier?
Answer
Answer
i need Surface Rapid Fusing for canon np 6512
Answer
jika copy melalui baypass atas,meskipun ditambah tinta,hasilnya bersih tidak kotor,tapi bila dicopy... (More)
Answer
We close the stack bypass, but it still tells me to close the stack bypass cover. I found the... (More)
Describe your Copiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
in Van Nuys, CA
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
