Question about Maytag MMV4205 Microwave Oven
Maytag model mm4205aa
My maytag model mmv4205aa stated to smoke from the right and a loud noise was heard . I disconnected the microwave, afraid of a fire would start.
Do i need to get a new one ,or can i repair it
  • Maytag Master
  • 9,098 Answers
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smmoth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
Burning smell and loud grinding noise
If that grinding noise sounds a little like gargling into a coffee cup, that's a defective magnetron.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jan 09, 2013 | GE JVM1441 Microwave Oven
Maytag model mmv4205aa have electric no power in micrcrowave
This previous answer should help you.
Aug 31, 2012 | Maytag Appliances Over-the-Range Microwave...
Need to replace the door on MMV4205AA
You can find handy exploded views and order parts by model number here.
May 31, 2012 | Maytag MMV4205 Microwave Oven
My LG microwave Model No MG555F made a loud explossive sound while warming rice gruel and continued to work normally; the incident repeated while I was warming fried fish; the machine continued to wor
The sound you heard was an internal ARC/Short in the Magnetron which creates the microwaves, This is an imminent sign of complete failure, Due to the decrease in prices of new microwaves it is no longer economical to repair them so start looking for a good special on microwaves.
Mar 04, 2012 | Microwave Ovens
Hello, I have a maytag microwave model #MMV4205AAS As I was reheating something the power died. I checked and there is power to the outlet. Is there something else I should try?
There is a problem inside the microwave oven.
This could be thermal in nature - in which cae the oven will operate again after a cooling period (which might be as long as fifteen minutes), or there could be a problem which caused a protective fuse to rupture.
I do not advise opening these appliances unless one is fully aware of the associated risks.
Jun 08, 2011 | Maytag Microwave Ovens
Microwave has no power mmv4205aas was working just fine and then just stoped
This is most likely a dead magnetron (microwave production) or a dead transformer.
These are the most expensive bits of a microwave, so unless it is of sentimental value, a new unit is actually cheaper than a professional repair.
Feb 09, 2010 | Maytag MMV4205 Microwave Oven
I was microwaving frozen broccoli in my Kenmore microwave and I heard a loud grinding noise which made me turn to look and saw that the interior was on fire. Once I stopped it and opened the door it went...
The magnetron is failing is what it sounds like...what is the make/model?
Replacement is usually the best option in cases like this btu I need to know the make and model # before I can say that for sure.
Sep 10, 2009 | Microwave Ovens
Maytag microwave mmv1153aaw
my guess would be the wave cover. sometimes they smoke and makes sparking sounds. does it still heat food?...if it does, then its not the magnetron.
Feb 18, 2008 | Maytag MMV4205 Microwave Oven
Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
Jul 31, 2007 | Whirlpool GH4155XP Microwave Oven
Maytag MMV4205 Microwave Oven Logo
149 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
