Question about Kenwood KSC-WD250 Car Subwoofer
Wiring a Kenwood KSC-WD250 Subwoofer
HI, I have a Kenwood KSC-WD250 Powered Sub but do not have the 10 pin power wiring harness or the remote control unit. My question is- does anyone out there know the connections for power, gnd, and switched remote power (blue/white wire)? I using the RCA level inputs. Also, will the unit work w/o the remote control (I can use the head unit control)? Thanks!
  • 2 more comments
  • philsan Dec 06, 2007
    I have the same problem but I have the power lead. I can control the sub from the head but is it as good as the remote?
  • Bren Bagnall
    Bren Bagnall Feb 05, 2008
    So your saying you can use the rca cables instead of the wire harness if you dont have it...What about if you don't have the remote as well?
  • Powerhead Mar 18, 2008
    I too am missing the wiring harness for my Kenwood KSC-WD250. (It was left in my old car when I removed the sub.) My new vehicle is already wired with RCA cables for a sub-woofer. I can purchase a new wiring harness online but a replacement remote is too expensive. Do I have to install the wired remote to make this sub work or can I just use the car's head unit to control the bass? Thanks!
  • JDMBrosdude May 16, 2008
    I have the the harness and the remote and I am gonna install it with a buddy and we need to know what wires are what ???
  • 7 Answers
Wiring a Kenwood KSC-WD250 Subwoofer - 7e83231.jpgI had the same problem Here is the diagram i used from someone else on fixya.  Thank you.
Posted on Jul 21, 2008
    Sergeant:
    Champion:
  • 231 Answers
Yes blue/white is for remote on/off from radio or you can use 12 volt switched behind the radio or from car fuse block .The 10PIN connector on sub is just for speaker level inputs.Since you are using RCA you wont need to use it
Posted on Dec 07, 2007
  • Brent S Oct 17, 2016
    That is incorrect. The 10 pin connector has power and ground connections, not just speaker connections. The rca cables are for audio input.
    New Friend:
Does that mean I have to connect BOTH yellow wires to the battery, and BOTH black wires to ground?? I'm stuck...
Posted on Oct 17, 2016
I have a kenwood ksc-wd250 subwoofer and the wire harness thats on the amp has 2 blk wires, 2 yellow, 1 blue w/white stripe, and 2 green and 2 purple wires. How do I wire this into my system. What color...
Sounds like thats for high end speakers.....should connect rca cable to the input and only other wires should be positive (b+) ground (negative) and remote (blue wire)
Mar 27, 2012 | Kenwood Car Audio & Video
How to disconnect Kenwood KSC-WD250 Powered Subwoofer from my car stereo
There should be RCA's power and ground connections. the rca's run behind the stero, the ground runs somewhere to the frame of the car and power runs to the positive post on the battery.
Jun 11, 2010 | Kenwood KSC-WD250 Car Subwoofer
How do you hook up a sub and amp to a stock radio with NO RCA outputs?
you can splice into the wires for your rear speakers and install some of your owns rca's and just use the low pass filter on your amplifier to eliminate the mids and highs from the frequency to your subs.
Jun 24, 2009 | Kenwood KSC-WD250 Car Subwoofer
Where do you buy the 10 pin connector
I used a computer power cable (the one that plugs into your IDE HDD) and soldered the male end onto the circuit board. Sorted :)
Apr 13, 2009 | Kenwood KSC-WA82RC Car Subwoofer
Installing self amplified sub to factory stereo
Hello Jax GS300,
Yes, you can use RCA cables. Just wire in a "low-level" converter.
Using RCA's is really the best way, allowing you to run shielded wiring to the sub, making it less likely that the wiring will pick up electrical interference. I'd install the converter on the rear speaker wires behind the dash.
If you do not want to convert the speaker output, you can drive the Kenwood directly from the speaker wires. The diagram in the install manual shows the connections coming off the rear speakers.
Here's a link to one output converter. This one will convert all 4 speakers.
http://www.crutchfield.com/p_142SLC4/Scosche-SLC4.html?search=level+converter
Hope this helps.
Apr 09, 2009 | Kenwood KSC-WD250 Car Subwoofer
Replacement Kenwood KSC-WA82RC Car Subwoofer remote control wire
It looks like the S-video you need one end to be male and the other is female end.The high quality the S-video wire the better the sound.Make sure you get a long enough cord. Take it with you to radio shack or and car audio or home audio find the female end of the S-Video and it should plug in perfect.Wire it up and enjoy some tunes
Oct 16, 2008 | Kenwood KSC-WA82RC Car Subwoofer
10 pin plug wiring configuration
7e83231.jpgI had the same problem.  Here is the picture I used.
Oct 05, 2007 | Kenwood KSC-WA82RC Car Subwoofer
Kenwood receiver/sub problem
The amp's remote turn-on wire is probably connected to the blue wire coming from the back of the stereo - this is intended for a power antenna, which is why it only works when listening to the radio. Disconnect it from the blue wire and connect it to the blue/white wire coming from the back of the receiver and you should be good to go.
Sep 21, 2007 | Kenwood KSC-WD250 Car Subwoofer
Connector Pin Out
Apr 05, 2007 | Kenwood KSC-WA100 Car Subwoofer
Car Audio & Video Logo
7,461 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
