Question about Plumbing
Kitchen sink has good cold pressure but hot has decreased recently. aerator is clean. how do i clean cartridge on 67551-0308D2
    Habit-Forming:
    Scholar:
  • 93 Answers
Is hot water pressure low at all faucets..if so, suspect a clogged or faulty hot water heater.
Posted on Apr 28, 2019
4 Suggested Answers
SOURCE:
  • 74 Answers
SOURCE: No water pressure in kitchen sink. Not the aerator.
First of all we like to check the easy/cheap things first.
1. Are the shut-off valves closed lightly?
If they are closed, open them.....easiest fix of them all.
2. If the valves are open then possibly a washer is shifted.
Turn off the water supply at the valves under the sink. Remove the handles by removing the set screw under the handles. There should then be a packing nut which holds all of the "guts" of the faucet in. Remove this nut and pull out the long stem. On the bottom of this stem is a flat washer that may have been damaged or is just slightly shifted. EIther way, I would replace it if the faucet is more then a few years old as it is cheap and you already have access to it. WHen replacing the valve stem, be sure to use a plumbers grease on all rings and seals. The rest of the replacement is the same are the removal.
Hope this helps.
Posted on Apr 25, 2009
  • 94 Answers
SOURCE: sudden loss of water pressure to kitchen sink.
check your supply tube's under sink,are shut off valve's wide open , any hose's kink'ed just a few thing's to check.
Posted on Apr 25, 2010
  • 125 Answers
SOURCE: No hot water pressure in kitchen, low cold pressure
sounds like a bad faucet//only if you had good pressure before it was installed..to cheaply test..take the hot water off from the shutoff valve and spray it into a milk jug to see if theres good flow..then replace the faucet assmbly..dont forget to turn off the shutoff valve first..or you will get a watery surprise!
Posted on Jan 08, 2014
Testimonial: "Did that, not water is coming from the valve at all"
No hot water on New Kohler touch less kitchen faucet. Had plenty with old faucet I'm replacing.
You need to make sure that the small flex line going to the water supply is not kinked than if that dont work make sure theres no trash in the cartridge
Oct 05, 2016 | Kohler Plumbing
Jan 08, 2014 | Home
We flushed our hot water tank and after that we have very little pressure our 122-426 b&K kitchen faucet. Changed the cartridge and cleaned the aerator
There's a little filter in faucet head and it may have got backed up with calcium from old water heater when changed.. U can just pop it out with lil knife and then run faucet with hot water to get any build up.. U can pick up more screen filters at local hardware store for cheap..
Jul 27, 2013 | Plumbing
It sprays fine but off the spray thair is no presuser . we replaced the water lines in the house we have good preasure though out our home jest not at the kitchen sink
One of the greatest things about Franke Faucets is that they have a lifetime guarantee. If you recently changed the waterlines in the home then more than likely when the water was turned back on or lines pressurized the settlement in the water main (Outside of your home) was activated and clogged the aerator. Most aerators simply turn counter clockwise (With the water off) after remooving the aerator simply clean and dislodge any particles in another sink. As for the pull out, some models have an inline screen located between the hose and the faucet handle. Simpy remove the handheld faucet (With the water off) and clean the screen.
Feb 02, 2011 | Franke FF-303 Kitchen Faucet with...
I have a brand new faucet not getting any water pressure? Water Pressure was fine before putting new faucet in. How do i troubleshoot this problem and get my bathroom sink running properly again?
It is very common when you first install any faucet, for the aerator on the very end of the faucet (where the water comes out into the sink) to plug up with rust or sediment. Because you had to turn off water supply, it churns up this sediment in pipes. It initially plugs up the filter/screen in aerator. Just unscrew the end & flush it out with water. Then reattach.
Jun 16, 2010 | Peerless Industries Peerless Chrome...
Water runs slow
Three possible reasons for low pressure. 1. faucet cartridge has debris in valve body. 2. aerator has debris ,just unscrew and clean out. 3. Water valves under sink are not opened up. hope this helps
Jul 30, 2009 | Price Pfister Marielle Kitchen Faucet with...
Low water flow and pressure
remove aerator and cart. and soak in limeaway over night
May 21, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
American standard kitchen faucet roars when hot water turned on
Not the aerator at all as this part would act the same if hot or cold.
Have you checked the shut-off valves under the sink? Sometimes just turning them a bit in either direction will solve that problem (will only be the case if it have been shut off at the valve recently).
Also, maybe the supply line on the hot side have been kinked?
Hope this helps
Apr 11, 2009 | American Standard Plumbing
Plumbing Logo
43 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
