Question about RCA Televison & Video
I was given a new rca TV DVD combo. First time trying to use the DVD it says no disc. Now I cant get it out
SOURCE:
PCTServices
  • 120 Answers
SOURCE: TV says WRONG DISC TYPE
is the dvd a store bought disc or a burnt dvd? If the disc is a store bought disc I unfortunately can't help you. But if the dvd you are trying to play is burned from dvd burner you are most likely using the wrong type of burnable dvd. There are two types of dvd's you can burn, DVD-R and DVD+R. You need to make sure which one you dvd player can play, some play one or the other, some play both. I have also heard of some older ones that can't play any type of burned disc. Hope that helps Peter
Posted on Aug 18, 2007
  • 4 Answers
SOURCE: Need code for Emerson TV,DVD,VCR Combo
I don't have a code book for you, but I can tell you how to program the RCR660 using the automatic programming feature.
Programming RCA model RCR660 (no code search button)
While following these instructions, keep the following in mind:
device = the component you wish to control with your remote (TV, DVD, VCR, etc.)
DEVICE = the button labeled for the component you wish to program
1. Turn on the device you wish to program.
2. Turn off all other devices in the general vicinity.
2. Press and hold DEVICE
3. While holding DEVICE down, press ON/OFF and hold them both down until the LED turns on for that device.
4. Release both buttons.
5. Point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing.
6. If the device does not turn off, then continue to press PLAY and wait the required interval (for a maximum of 20 times) until the device turns off.
7. When the device turns off, press REVERSE, wait two seconds and continue doing this until the device turns back on.
8. To finish programming, press and hold STOP until the LED turns off.
Posted on Dec 31, 2007
SOURCE: i have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Posted on May 09, 2009
called comcast
Posted on May 28, 2009
dave1645
  • 834 Answers
SOURCE: RCA tv dvd combo L26HD35D programming codes
not gonna happen
Posted on Sep 20, 2009
Connect rca tv cable box vcr dvd
the problem is in the vcr/dvd player
Jan 05, 2014 | Sharp Aquos Televison & Video
Dvd won't eject from RCA tv/Dvd combo
While hitting the eject button use a small flat screwdriver or butter knife to ease door open, probably the rubberband like belt broke or the gears jammed up!
Jun 17, 2012 | RCA 22LA45RQD 22-Inches 720p LCD TV -Black
American DVD discs will not load and play, but overseas discs will
no the coding would not change from using the dvd's from overseas. the ones that you say are american may not be american and that is most likley the problem. try putting in a dvd that you have had for a long time that you bought here in the states and if that works then the dvds you say are american are the problem.
May 31, 2009 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Dvd disc wont come out
It has happened to me several times. What works for me is to unplug the tv, wait a few minutes, plug it back in and the dvd comes out ok. Good luck.
Apr 05, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
I want to connect my sound system to my tv
Your television is either going to need Video Out, or if you have a VCR or VCR/DVD combo connected to your television. Assuming that you have a VCR combo, the way your tv should be set up is on the back of the vcr combo, your cable will run into the coaxial IN and then you have another cable running from Coaxial OUT to your tv. If you have it set up like this, then the DVD / VCR combo will have RCA Audio / video out ports on the back side. Run RCA cables from the DVD / VCR output to the surround sound INPUT. If you already have your inputs in use on the surround sound, Radioshack has RCA splitters for about $1.50 each, you might need to pick some of them up so you dont have to go through the trouble of reaching behind it all the time to disconnect and reconnect whatever your trying to connect. Now if you dont have the DVD / VCR combo, then your TV "MUST" have RCA Outputs. if it doesnt, then the only way that your going to have your surround sound connected to your tv is to take the TV apart and get a RCA "Line output converter" and wire it to the left / right channels of your tv. From what I've read, i think this is what your trying to do so I hope this helps
Jan 20, 2008 | Durabrand STS92 System
Sylvania 6720FDE combo tv/dvd/video
The codes for a combo set are found in the DVD settings or the VCR settings. Try the rca codes for DVD or Vcr and it should work. Although you may find that not all the functions will work properly ( ie: fast forward, open door, etc ). Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Wrong Disc
You now have a optical block problem. An alignment may do the trick, but you'll be out the estimate if it's a major repair and you refuse to dump more cash into it...accordianman
Dec 29, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
20F510TD RCA
20f510td rca cant get past the pass word input....
Oct 13, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
Aug 18, 2007 | RCA T09085 9 in. TV/VCR Combo
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
