Question about Sharp Office Equipment & Supplies
Sharp mx-m850 code error c1-01plz help me sir
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 160 Answers
  • Charger cleaner trouble (K). Causes. The main charger unit (K) is not installed properly. There is an abnormality in the main charger
Posted on Apr 17, 2019
SOURCE:
SOURCE: Help
Sorry bubbabear 64, you are wrong you need to reset the copier with sim 14, once you have cleared the jam, there is no sensor in the fuser so often if the paper gets crumpled in there is doesnt trigger and sensors so the customer trys to copy again and again, seen it many times.
John Sharp Tech
Posted on Jul 22, 2008
  • 24 Answers
SOURCE: error code h4-01
P * C * enter sim 14 press copy key then CA. Machine should reboot. if problem re-occurs your thermostat in the fuser has tripped
Posted on Dec 01, 2008
SOURCE: Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Posted on Dec 11, 2008
  • 8 Answers
SOURCE: I got call for service code: h5-01 I already took
press these keys
#, *, c, *, or
#, *, c, #
if input correctly copier will ask for simulation code
type in 14 then start
01 then start
if it ask are u sure after inputing 14 then start hit yes or 1 for yes or execute. copier will restart. all will be fine untill the next three jams
Posted on Aug 17, 2010
SOURCE: sharp ar5516 f2 error
We have bought this machine on Date-28/07/2011 and it is still in warrenty. now already 11,000 copies put it And the now machine shows F2 indication after starting and the company not repairing it. And the after sell service of company is not good.We tell the company to change the the machine or repair and they neither repairing it nor changing the part.
I request you to solve my problem please.
Posted on Dec 14, 2011
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
What means E7-20 error code for sharp mx-m850
The code refers to the laser beam detection in the laser assembly.
The first thing to do is completely power the machine off & then back on to see if the machine resets. If it doesn't reset then the fault lies with the laser assembly itself & would require a technician to strip the machine to locate the problem.
Dave.
Jan 20, 2016 | Sharp Office Equipment & Supplies
H5-01 ERROR CODE
The following is from the Sharp website on error codes: SHARP MX M503N ERROR CODES Trouble Codes
H5 01 = 5 TIMES CONTINUOUS POD 1 NOT-REACH JAM
Mar 03, 2015 | Sharp Maintenance Kit 1 Mx-m700u Mx-m700n...
MX m354u. What does error Code U2-91 indicate?
This seems a common error across a wide range of Sharp printers/copiers. It means
PCU PWB EEPROM CHECK SUM ERROR
See the following two links (for example)
Thread U2 91 on MX 5000N and SHARP MX M363N ERROR CODES Trouble Codes
If haven't got manuals or other documents which may contain helpful information they can be downloaded here. This link also contains contact information for sharp so that you might get support
MX M354N MXM354N Digital Copier Printer Sharp
6.November.2015
Feb 27, 2015 | Sharp Office Equipment & Supplies
We are getting a VK maintenance code on our MX-M850 copier. Does anyone know what it is and how to fix it?
This is one of the scheduled maintenance codes. it comes on at a certain "milage" and requires a technician to reset it.
If you're in Houston we'd be happy to help you out, and supply new machines should you need any.
Skelton Business Equipment Houston Copiers
Jun 19, 2014 | Sharp MX-2700N Color Copier
Error Code U2-81 from sharp MX-M314N copier How to fix it
Dear sir; This error code means "scannor memory" problem, don't worry, we can reset it, the procedure as follow;
1, make sure you are in copy mode , then press "p", "*", "clear", "*".
2, enter 16 press start.
3, press "CA" to end simulation.
that's easy, if you need more help, just let me know, good luck.
Feb 12, 2013 | Office Equipment & Supplies
26 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
