Question about Saeco Coffee Makers & Espresso Machines
Bought new Saeco Incanto, first refill of beans and the bean hopper door shows as not closed, small ring fell off. How do I override so I can have a cup of coffee out of a damn $700 coffee maker I haven’t gotten a single cup from yet?
    Top Expert:
  • 29,866 Answers
Refit the part that fell off.
Posted on Apr 06, 2019
SOURCE:
JohnnyBeans
  • 223 Answers
SOURCE: The Coffee bean holder
You may have accidentally dropped water into the grinders. Email me your email address and I'll send you grinder cleaning instructions.
If the grinder cleaning does not work.. You may have to have to machine serviced.
Please include the model of machine and that you would like the grinder cleaning instructions.
Email: support@cerinicoffee.com
Posted on Oct 12, 2007
SOURCE: Saeco Incanto Flashing Red Bean Light
I found a machine in my dentist's office with this exact same problem. I'm not familiar with the model, so I downloaded a manual for the closest model I could find online (the Sirius), and it offered no help -- but in 8 languages!
I ended up just pulling the drip tray, pulling the box where the grounds end up, and re-inserting the assembly (all while the machine was on.) When I buttoned it up again, it worked.
Hope this helps (although I can see how it might not...)
Posted on Nov 15, 2007
  • 1089 Answers
SOURCE: gaggia titanium coffee beans empty
Hi
If the big knob in the bean hopper is on a small #, that could be your problem. try opening the knob to the largest # and try again. If it clears and makes a cup, then on the next cup, while the grinder is operating turn the knob down again, but to a larger # than you had before. Grounds can get compacted in the chamber and prevent new grounds from entering. That is why it grinds but doesn't make a coffee. If that doesn't help, try opening the door above the brew unit funnel when the brew units is out. It should pull down on a hinge. This is the clicking you hear when you make a coffee.
Posted on Oct 20, 2009
SOURCE: Saeco Incanto S-Class Sirius coffee machine not sensing beans.
I have had the same problem the only way I could get it to brew would to use the program quantity feature every time. I was going to take it in today and decided to restore the factory settings and now its working like it should. This seems to be a circuit board issue Ouch! I have another issue with the steam, if I take the knob off it works if I don't it doesn't glad I bought a 2K model GRRRRR!
Posted on Jan 25, 2010
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
make sure you use very dry non-oily coffee beans
Posted on Jan 31, 2011
I have a Incanto Classic. I put in whole beans and it brew the first shot without a problem (the puck formed after) . I have since tried it again and no espresso (liquid) comes out. The grinds were...
Hi
The small knob in the bean hopper is set to the max or + side. Turn the small knob back 1 mark and try again.
http://www.fixya.com/support/r3658318-superautomatic_not_make_espresso_dumps
Sep 19, 2011 | Saeco Incanto Classic Espresso Machine
The plastic shield in the coffee container on my saeco incanto de luxe broke yesterday and fell directly onto the beans, but I was still able to make my coffee this morning, but this afternoon, the...
Vac out the bean chamber, then remove the 2 or 3 screws and carefully lift the bean hopper off the machine, then continue cleaning the grinder, careful not to lose the gasket around the top of the grinder. When done reassemble and try to brew but do not add beans to hopper as yet. Until you are sure all the plastic pieces are out.
Sep 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Make coffee stronger on a saeco machine
Hi, adjust coffee amount knob more towards +, which will grind more coffee for brewing. The knob is the smaller one inside the bean hopper.If the machine has digital display(Incanto Deluxe) it can be set in the menu.
Jul 29, 2010 | Saeco Incanto Coffee Maker
Grinder Blocked said on screen. Any Quick fixes?
This has happened to me twice. Usually caused by a trapped bean in the grinder. Here is how I fixed it. It is easy.
Inside the plastic bean hopper is a screw located in the bottom. Remove it and lift off the hopper. Have someone help you as you turn the machine upside down to remove all the beans. Use a tooth pick or a wooden skewer to pick out any beans lodged inside the grinder housing. Once completed, return the unit to its upright position.
Look inside the hopper and locate the grinder stem which is gold colored. On top of the stem is a hex bolt. Take a hex wrench with a 7/16 hex socket, connect it to the grinder hex bolt and turn it "counter clockwise" about half way which is the same direction the grinder turns. Add some beans and see if it works. If not, turn the hex bot "clockwise" a half to a full turn. Add beans and check.
This helps move the grinder out of its "stuck" position.
Nov 03, 2009 | Saeco Incanto Sirius Fully Automatic...
My bean light won't stop blinking red!
Hi
Turn you big knob in the bean hopper up all the way to the largest #, then try again. If it clears the and makes a coffee do it 1 more time then turn the big knob back down while the grinder is running but don't turn it down as far as you had it before,(1 to 2# higher)
Mar 30, 2009 | Saeco Incanto Classic Espresso Machine
Incanto de Luxe always tells me there are no beans in container
I do have the same problem.
I have removed and cleaned the grinder mechanism.
Being an electronic technician I did have a look and tried to find what method they use to detect that the new beans reservoir is empty and I did not see any kind of detector.
I suspect that they monitor the motor current to do this. If it is so would'n it be possible to desable this fonction since it is more then evident when the reservoir is empty or about to be?
Any body knows how they do monitor the status of the new beans reservoir?
Dec 18, 2007 | Saeco Incanto Classic Espresso Machine
Nov 10, 2007 | Saeco Incanto Classic Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
