According to the manual, the "ble fail" message indicates that there is a problem with the Bluetooth Low Energy (BLE) module. The manual suggests the following steps to resolve the issue:
Turn off the treadmill and unplug it from the power source.
Wait for 30 seconds and then plug the treadmill back in.
Turn on the treadmill and check if the "ble fail" message is still displayed.
If the message persists, contact Bowflex customer service for further assistance.
sounds like you should read up on how to re install android on your tablet or maybe flash cyanogenmod 11 to it, ur current install is corrupt you could try removing all google apps and clearing their cache/data
normally it happens when theres some issues with the carrier or provider. e.g. the sender of the message was getting message sending failed and they tried to resend the message until they got the message sent. if the sender was getting message failed for x times then you will receive the messages repeatedly.
blue tooth needs to be turned on from the connectivity section of the phone menu.
Once it is turned on it will pair with any bluetooth device.
PAIRING A BLUETOOTH
Go to connetivity in the menu
then bluetooth and then search and sellect search.
with your bluetooth device from the off status press and hold the power button until indicator lights either flash different colours ( normally red & blue ) or stays a constant colour.
Your device is now sending out a signal for the phone to pick up.
when the phone finds this device it should then ask if you wish to pair with it
select yes
then it will ask for a passcode this is normally 0000 or 1234
then select yes.
this should pair up the two devices.
once they are paired you should only need to turn bluetooth on on the phone and power up the device and they will automatically find each other.
Please don't do this whilst driving as it is extremely dangerous to take your concentration off the road.
I have a motorizr z3 that I purchased a week ago. I cannot get the blue tooth to turn on. I ONCE got my Plantronics bluetooth synced but it would never turn on again, so I deleted it off, and now everytime I try and turn bluetooth on, I get a message of "Bluetooth Power Failed - try again later". It tells me the same thing when I try Setup or Find Me...any ideas how to get this to work?
aah same here.. i have the same problem with my motorola v500.. i've tried so many times to power it on and it just says "bluetooth power failed".. its really annoying..
please help!
