Question about Toshiba Televison & Video
My Toshiba tv model 55HT1U power issues. The electricity went out in our grid and now after I turn off tv it will turn itself back on after about 9 Minutes. Any suggestions?
Check power settings
  • brett duck
    brett duck Apr 06, 2019
    Hi Launa Sparks-Hunter, thinking about hdmi control devices plugged into tv
    like a dvd player
    or a x-box
    or a play station
    try powering these devices down for 1 minute
    then power back on
SOURCE:
  • 192 Answers
SOURCE: Electricity went out in town, tv won't turn back on.
On this type of problem, the first thing I check is the AC line fuse on the power supply. Follow the Ac plug wire to the power supply board and where it plugs in, you will find the fuse. If: Then: It checks bad. Replace it. It goes out again. Call a Servicer. It is good. Check for the five volts that goes to the Main PCB. No five volts, change the power suppy (SMPS) Five volts is there, more than likely the Main needs replaced and SMPS. For a Samsung Servicer in your area: 1-800-SAMSUNG
Posted on Aug 19, 2007
SOURCE: 42" Planar Plasma turns off
your power board can cost 120-350
Posted on Sep 27, 2007
SOURCE: TV turned itself off, won't turn back on
I had the same issue with my 42HP95 after about two and a half years. Same symptom, red flashing power light, reset doesn't work and most of all, the last day of the Ryder Cup starts in 3 hours. Any other time (with exception of SuperBowl Sunday). I frantically searched the web for like symptoms and came across someone that posted the fix was to bypass the Seine Module but I had no clue what that was! So what do you do? Tear off the back of the TV and look for something that says Seine on it... Right! After that failed and 500 screws later, I decided to look for a Service Manual online. Nothing like RTFM (Google it!). I paid my $11.99 for a download Service-Manual.Net and found what appeared to be the Seine Module (SEIN). Through a little trial and error, here is what I came up with. The pic below shows the location of the said Module in the red rectangle.
78c6772.jpg I ultimately found that if I unplugged the connector from the module (in red circle) and put it in the cable management loop (other red circle), the TV would power on and has been working ever since.
According to the post I read (grains of salt) the SEINE Module is only needed if you are using coaxial type (rabbit ear) antenna. I personally don't know but it works for me. Granted, this is my experience and may not work for you but for $12, I am a happy camper. BTW, what a Ryder Cup!!! USA USA USA!!!
Posted on Sep 22, 2008
petraman7
  • 1175 Answers
SOURCE: tv turns itself off after 2 minutes. the power
Hi...
Main power supply is overheating. Try getting it dusted out first then check into getting it serviced
Posted on Apr 22, 2010
  • 1044 Answers
SOURCE: I need a pdf version
Please go to the following link and download the manual in pdf version
http://www.iusermanual.com/tv/toshiba-55ht1u-tv-manual.htm
Posted on Dec 08, 2010
My toshiba tv picture turned black and now it won't work. How do I fix it?
Sounds like main digital board is faulty. There is no start voltage comes out from it to the back-light inverter board to start functioning. If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 14, 2016 | Toshiba 55HT1U LCD TV
Why won't it turn on?
Fairly new TV will not turn on. - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions/Fairly...TV-will-not-turn-on/.../27334...
Feb 29, 2012 - My Toshiba 32dt2u1 television that I got this past Christmas will not turn on at all. I press the power button and it nothing happens. The green. Tv no power: Model 50L1350U
Jun 20, 2014
My laptop won't turn on!!!
Feb 19, 2014
40RV525U Toshiba LCD TV won't turn on.
Nov 22, 2011
55HT1U turns on by itself, wont stay off
Sep 19, 2011
More results from forums.toshiba.com
Questions & Answers for LCD TVs - Toshiba
answers.toshiba.com/answers/0293/category/...tvs.../questions.htm?...
Is my TV compatible with netflix? ... How do I reset my 32C120U tv so I can perform another channel scan? .... My tv won't turn on with remote or manually.
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
Jan 08, 2016 | Toshiba Televison & Video
Toshiba television won't turn on after power flicker
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
My flat screen tv cuts off and on while the power but is on what should i try before i buy a new one .... I have a ...
Toshiba TV power outage - AllExperts
en.allexperts.com > ... > TV/VCR/Stereo Troubleshooting
Feb 3, 2011 - TV/VCR/Stereo Troubleshooting/Toshiba TV power outage - no power... we had a power outage (they're calling rolling blackouts due to power grid ... but I admit I'm now afraid to turn it off for fear it won't come back on again.
Toshiba 32c120u LCD TV won't turn on - Tom's Guide
www.tomsguide.com/answers/id.../toshiba-32c120u-lcd-turn.html
May 27, 2015 - My toshiba tv is flashing but won't turn on with remote or power botton on tv itself ... dang this worked for me but after a minute it stoped working.
Dec 28, 2015 | Toshiba 58L7350U 58" 3D 1080p LED-LCD TV -...
Tv just went off in use. Power light blinking, will no turn back on
Set is in shutdown as a short somewhere.
If model indicated here is correct someone has to open it and check voltages in power supply first.
Apr 01, 2012 | Toshiba 36AF43 36" TV
Model 55ht1u
Hello!
Sorry, but I couldn't find any mention of P'n'P in this model's specifications.
Looks, like it just not equipped with that. Look at your Toshiba's remote control: if you don't see any PiP related buttons, it just not there. Definitely, has only one tuner, not for 2 tuner P'n'P broadcast. Some TVs must use external signal source for this feature, like an extra set top tuner box or DVD recorder with it's own ATSC tuner.
you may check TV's specs at: http://us.toshiba.com/tv/lcd/55ht1u/ .
good luck,
thanks,
Alex.
Jan 02, 2012 | Toshiba Televison & Video
My Toshiba 55HT1U volume not working when playing games
I believe you have connected your computer to the tv? Please note that if you connected via VGA or DVI it is a video only signal. You will need a seperate cable for sound output . Connect the audio out jack of your computer to the headphones port of a tv using a 3.5mm to 3.5mm connector like this
http://www.amazon.co.uk/3-5mm-Stereo-Jack-Plug-1-2M/dp/B00077DC3S
May 16, 2011 | Toshiba 55HT1U LCD TV
TOSHIBA 55HT1U only shows 480i resolution instead of 1080p ( Cable TV) shud be at least 720p
Your set will automatically be in the correct resolution. If your set is broadcasting in 480, then that is what it is receiving. I would check your cable or satellite box to verify they are putting out the correct resolution.
Apr 04, 2011 | Toshiba 55HT1U LCD TV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
