Question about NAD C372 Amplifier
No power Hi,Listening to music yesturday and all went quite, I went over to my NAD system and the AMP was swithched off! it wont switch back on again & the CD player is fine - confussed...Thanks..
  • 54 Answers
Unplug for 20 min. and then plug in to try and see if it will come back on.
Posted on Dec 01, 2007
Hi, I have a NAD C162 Pre-Amp which I am using with a NAD C270 Poer Amp. Th problem is that the Pre-Amp doesn't seem to be driving the Power-Amp efficiently. By this I mean i need to turn the gain up...
Hello, I have an idea:
at the rear side of the NAD preamp there is a switch, it can be in mode MM or MC . Please check it whether it is in right position or not.
Good luck,
gylacz
Feb 15, 2011 | NAD C162 Amplifier
Powers on, but screen is black It was left on and open a few inches while listening to music and it went black. When you turn the power on now it beeps a few times , nothing else
Dear friend you mention long beeps/few times beeps.
Its mean its RAM problem, Remove the ram from the ram slot & clean it by napkin & use a brash for cleaning ram slot. Then fix it back again. After that power on the laptop & see what's going. If the same sound again , that's mean the ram not working, its damaged. So buy/ arrange a working ram and fix it on the slot. Now power on and run the laptop for work.
Thanks & waiting for your reply.
Feb 05, 2010 | Fujitsu LifeBookS6120 Notebook
Iphone clone went off and wont start anymore
your phone has broken. Ask repair service from your seller!!! or you can contact www.eshopbing.com. they will help you free. good luck.
Sep 05, 2009 | Apple iPhone 3G
Need manual for ra 840bx4 & wattage output when remote speakers?
Lets try the simple stuff first. This whole problem could be caused by a dirty switch contact. Pick up some electronics cleaner from a local electronics shop and spray the switch (from the inside of the unit). Work the switch on/off a number of times then respray one more time. That should clean out any dirt that is there. Try the unit again and hopefully the problem is resolved. If not, then the switch itself may need to be replaced. When you get the cleaner, get one that contains a lubricant as well. This will help to prevent the problem from coming back again.
Dan
Jun 20, 2009 | Rotel Audio Players & Recorders
Audio Distortion after System Crash
sorry for the late reply. im using windows. im quite sure that there's no virus involved with the distortion of my sound. this is what happened.
1. im surfing the net while listening to music(full volume)
2.)then suddenly the sound gets a bit distorted(jumps,skips)
3.)then everything hangs up which forced me to reboot
4.)the windows loading screen became too long(like 5mins) before it takes me to the main desktop(start up programs loads like 48 years also).
5.)when i play music ,the sound is very much(like alien,"rrrrrrr")
i tried reinstalling the drivers but nothing was fixed. i've even tried Regcure.
i just formatted my notebook and voila its back to normal.
i dunno but i think playing loud music using laptop, or in my case notebook speakers would cause this problem. im using external speakers now and i've got no problems. i just hope that there would be a fix to this problem so that i wont have to reformat if the problem occurs again
Apr 20, 2009 | Acer Aspire One PC Notebook
No sound from amplifier on both channels
Hi...
All the main power supply capacitors need to be replaced.
I'm figuring it's an older unit?
Let me know
Thanks,
Scott
Mar 23, 2009 | NAD Audio Players & Recorders
Amp c352 TI 1515456 failure
It sounds like yo shorted the speaker wires together for a short time and smoked the output section of the amp. The amber light is an indication that the amp is in protect mode. If you attempt to power up the amp and still have the amber light even with all speaker wires disconnected, the amp needs repair. The output transistors for that side will need to be replaced.
Dan
Mar 05, 2009 | NAD C352 2-Channel Amplifier
Crackling power switch on NAD 3220PE
Hi, i would try flooding trhe switch with CRC 2-26 for a start. Itr may recover some contact integrity. A jerry rig solution would be to bridge the switch contacts and leave it on all the time(i leave my amps running all the time) or if as in Australia you have a switch on the wall socket use that,
OR purchase a new switch from here. Not sure how you would go through NAD, probably dont have any in stock as a spare these days.
or if that does not work out, I could get one to you through ebay. Used to be quite a common TV switch, but I also remember replacing then in Nad amps, many moons ago ;) I think I still have a one in stock myself, packed away from when I was a NAD service agent:)
regards
robotek
Nov 04, 2008 | Audio Players & Recorders
Can I connect a power amp to this unit?
If your 2100ES has a selectable INPUT AND OUTPUT and if you're intending to send all signal to the power amp, i.e. not bi-wiring or using the 2100ES to run mid-range or treble then you simply send Left & Right audio (White & Red cable) from a 2100ES output, probably AUX OUT ( it doesn't really matter apart from Phono on some units) straight to the power amp on AUX IN.
We should be just dealing with audio here, so connect the NAD audio output to CD or DVD IN. Select CD or DVD IN on 2100ES input switch and switch output to AUX OUT (whatever you decided goes to the power amp) on the 2100ES. Turn power amp to AUX IN and it will now get an audio signal from the 2100ES for amplification.
Speakers connect to the power amp as a normal amp, so pos and neg etc. The 2100ES now only acts as a signal feed, the power amp does all the work.
So, summary - switch on the NAD, press play - video goes separately and audio goes to the 2100ES. Turn 2100ES to INPUT for NAD. Turn 2100ES to OUTPUT allocated for power amp. Turn INPUT on power amp to allocation for 2100ES.
Turn it up!
Jul 27, 2008 | Sony STR-DA2100ES Receiver
NAD C372 Amplifier Logo
104 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
