Question about Samsung SGH-t629 Cellular Phone
Alarm clock doesn't work, t-mobile replaced the phone and the new phone does the same thing. it only works when you do factory resets.
    Brigadier General:
  • 7,752 Answers
Re: Alarm clock doesn't work, t-mobile replaced the phone...
Meme81 - Factory reset...allow you to clear the phone as if you just bought it from the store.
what you all should do is do a reflash of the firmware or upgrade need to take them to a mobile service center.
Posted on Jan 23, 2008
0 characters
3 Points
No response from host error message display on mobile screen when i connect cell with data cable
cleaned both point of your connector of your data cable and phone it could be dirt that prevent data to communicate.Isolate cable by brand new cable. If it is doesn't work reset your mobile to default factory settings.
Sep 09, 2011 | Nokia 2626 Mobile Phone
Alarm does not work if phone is switched off
If you turn your phone off, the alarm will not work, just as if you were to remove the battery and power from your alarm clock, it would not work.
May 11, 2011 | Samsung Galaxy S GTI9000 Smartphone
I can't find the alarm clock setting anywhere on my nokia surge phone! is this normal? I've searched everywhere for it, and it just doesn't make sense for there to not be such basic thing... I must have...
hiSelect > Tools > Clock To set a new alarm, open the Alarms tab, and select Options > New alarm. Enter the alarm time, select whether and when the alarm is repeated, and select Done. hope this will work. regards aniruddh
May 28, 2010 | Nokia 6790 Surge Cell Phone
How do you set the alarm clock on a motorola clutch i465?
There's an option in "Download Apps" from the "Java Apps" Menu called "Factory Preloads." Choose that option instead of the "New Purchases" option that you usually choose when installing other/new apps and it will give you a list of the default apps the phone came with. Alarm Clock Plus will be in the list.
You'll have the ability to re-download any of them, Alarm Clock Plus included. Make sure to uninstall the existing installation of Alarm Clock Plus first before doing so.
Mar 29, 2010 | Motorola Mobility Clutch i465 Cell Phone
My nokia 1110 alarm clock flashes when it goes of but makes no noise i have tried reseting the factory defaults and its not on charge so i cant see the problem. please help
Had the same problem with my dad's mobile.. Took out the battery & sim and put them back in (sort of resetting the entire system).. Worked perfectly..
Feb 19, 2010 | Nokia 1110 Cellular Phone
K850i,contrct from 3 ended got phone unlocked put in new sim to start new contrct, every thing works but txt . wont send or recieve ???? new network says my phone is bust tried new sim in other phone and...
This is a unusual symptom in a mobile phone, you should try a hard reset and a factory reset.
1. Hard reset, take the battery out for 30mins and try again
2. Factory reset will reset your phone to factory default settings to so this just go in the settings option and then find the reset option make sure you choose the total reset option
Hope this helps
Nov 14, 2009 | Sony Ericsson K800i Cellular Phone
Phone powers off automatically with the SIM card
hi, you can try to do factory reset,it don't make any harm to your mobile.if it doesn't work.we need to check with the sim holder,that may also cause of this problem.
Aug 18, 2009 | Nokia 6133 Cellular Phone
The alarm clock stopped working
try resettign the phone but it will delete evrything on it. since you already tried cheking it. go to menu-setings-reset settings-phone settings.
Jul 01, 2009 | Samsung Katalyst SGH-T739 Cellular Phone
The external display on my blackberry pearl flip is empty
i had the same problem. i reset the alarm to go off immediately, then dismissed the alarm. i also reset the default theme. the clock came back to the external display and the daily alarm message went away!
Mar 05, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Alarm clock not working on Nokia 1100
i am having a nokia 1100, alarm and reminder are on on mode. however it is not making any sound.
Sep 01, 2008 | Nokia 1100
Samsung SGH-t629 Cellular Phone Logo
37 people viewed this question
Top Samsung Cell Phones Experts
Steven Wander
Steven Wander
Fred Sops
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
