I am trying to connect to W i - F i . There is a connection but, server not found. Is it my browser?
How would you know if there is a connection. in the manual of the router, or below the unit, there should be a sticker that says IP address and might read something like 192.168.1.1 or equivalent. Now, go to Start - run - cmd in your router and type in Ping the numbers you found there. if you get 'reply from 192... " 4 times, it means you have a valid connection between your computer and the router, else no .
If you get a reply, then try ping 4.2.2.2 which is a universal DNS. if you get replies for this, then it means you are able to connect to the internet but not able to browse. then it could mean a browser issue.
I would suggest you try another browser / pc to make isolate the problem
Thanks
Ranjit
[email protected]
SOURCE: can not find server when connected to wireless 2wire 2701hg-b
have u check the ip address if ur getting a valid one? ping an ip address first see if ur getting a valid results if not try to reset ur tcp/ip, if yes try to flush the dns server.. also let me know if what OS u have.. thanks
The 404 or Not Found error message is a HTTP standard response code indicating that the client was able to communicate with the server, but the server could not find what was requested.
The web site hosting server will typically generate "404 - Not Found" web page, when users attempts to follow a broken or dead link, hence the 404 error is one of the most recognizable errors users can find on the web.[1]
A 404 error should not be confused with "server not found" or similar errors, in which a connection to the destination server could not be made at all. A 404 error indicates that the requested resource may be available again in the future; however, the fact does not guarantee the same content.
I hope this helps
what is the signal strength? secured wireless or unsecured?
