Robert Souter Posted on Apr 03, 2019
InFocus LP600 is projecting backwards, how do I change
5 Related Answers
Anonymous
  • 26 Answers
  • Posted on Feb 28, 2008
SOURCE: InFocus LP600
If the counter expired, then the reset is holding both volume keys down for 10+ seconds.
Anonymous
  • 82 Answers
  • Posted on Jul 26, 2009
SOURCE: infocus projector, words projects backwards
change the orientation from rear to front in the menu
projdoc
jasbo
  • 2239 Answers
  • Posted on Mar 18, 2010
SOURCE: the InFocus LP600 won't power up
power supply. this model has a problem with them.
Anonymous
  • 269 Answers
  • Posted on May 04, 2010
SOURCE: InFocus LP600 - A vertical shadow on the Left-side
The light tunnel inside the "engine" is either out of alignment or the glue holding the tunnel together is coming unglued and 1 of the 4 sides has fallen in. There are 2 screws to adjust this if the tunnel is still intact. One or both screws can be accessed by opening the lamp door and then you have to remove a thin sticky cover. You will see 2 small screws that will have to be adjusted with a small torx (3) or allen. You will have to have the safety switch pushed in with something and adjust while the projector is on, using the most easily accessible screw, turn it towards the direction of the "banding". It should decrease. If not, turn the screw the other way. The screw that is not so easy to get to is for adjusting the banding the can appear across the top or bottom of the screen. If the banding gets worse or even starts to show diagonally across the screen, it is a good bet that the tunnel has collasped.
wadekier
  • 4 Answers
  • Posted on May 05, 2010
SOURCE: lp600 won't strike
Hi Folks
I had a bulb "expire" on me (went out early), giving the "Lamp didn't strike" message. I replaced it with a spare and unfortunately that gave the same message. I RMA'd it to InFocus who "fixed" it, citing a bad bulb. "What about the spare I used?" I asked. "Oh well" was the answer.
I got the projector back, tested it and it worked fine. So I decided to test the spare bulb I had previously, still got the "Lamp didn't strike". I thought "bad bulb after all". So I put the bulb InFocus had fixed the projector with back in, started the projector and received the "Lamp didn't strike". (ie, a known good bulb). Oh ****.
I left the cover off, jimmied the safety catch and restarted the projector, heard some snapping which reminded me of a bad electrical connection. I popped the top cover off the projector and saw where the electrical plug was that the lamp plugged into. It looked fine from the top-side and the bulb compartment, but when I used a small screwdriver and pushed on it, it dropped a quarter inch and a little plastic tab reseated itself. I realized when I had put the spare bulb in initially it had pushed on the electrical connector, not quite lined up, and pushed it up slightly into the body of the projector. The bulbs looked like they were plugging in, but the connector had moved enough the bulb wasn't making contact, so not getting power through the plug. Once I pushed the connector back down into place, I put my original "spare" bulb in, carefully lined up the connectors, and it fired up fine. (Big relief).
If you find this helpfull or need more details feel free to e-mail me
wade.kierstead at city.fredericton.nb.ca to let me know!
Thanks
How do I reset the lamp timer on my lp600 projector
You can't. You'll just have to make note of it's current reading just like an odometer of a car when you replace a new bulb.
31helpful
4answers
HI I WANT SERVICE CODE OF INFOCUS LP600 ASKC175
I am not exactly sure what service code you are searching for, what is happening with the projector? You turn it on and immediately it's looking for a code? Please let me know and I can help
Tim
The infocus LP600 won't power up
make sure the lamp door is engaging the safety switch. manually reset the lamp hours and reflash the software, if that don't work it's most likely the power supply.
I am looking online for a Service Manual to download for the Infocus LP600 projector Can you direct me to where one may be available?
you won't be able to get one for free. infocus service centers are prohibited from releasing that info. if you want a user's manual, try www.projectorcentral.com
9helpful
5answers
Infocus projector, words projects backwards
Self Shutdown of my Infocus LP600
power supply problem. if it was overheating, it would go into cooldown mode then standby. there is an issue with the power supply, and it needs replacing. it's about $100 from infocus.
Tunel de luz
Last time I checked, the light tunnel was available. It is a special order and cost $52.80 plus shipping.
Infocus has discontinued parts for a number of their projectors. If it is still available, it could take as long as 4 weeks.
InFocus LP600
Lp600 went dead
i had the same problem with my 2 years old infocus lp600. on the mains section of the power supply board you have 4 100uF/16v and 1 4,7uF/35V electrolyt condenser of a 85 degree type. that means it will work 2000 hours at 85 degree (celsius). since the power supply only switch off the lamp in standby with no fan the power supply get hot- i think about 70 degree. so after two years in stanby it is evident that this condensers loose halve of their capacity - after switch off no new start. changing this condensers with new ones of 105 degree type will solve tis problem. and for the future - no more stanby.
Top InFocus Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
