Question about Frigidaire GLMB209D Microwave Oven
Microwave over the stove
It blew micro wave ceramiic fuse so it was replaced and it blew the new fuse in the micro again
  • Frigidaire Master
  • 9,098 Answers
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
It may also be a problem with a door switch or door switch mount.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
Where are the fuses in my microwave oven,?
Inside behind the display panel on a small circuit board.
Jan 01, 2013 | Magic Chef MCO160UB Microwave Oven
Microwave sometimes heats up food and sometimes it does not.
usually when you kill the power and then when you put power back on the machine works it's the computer board that's bad.all you're doing is resetting the board just like your house computer,if something happens to it you shut it down and reboot it,that's what you're doing with the micro wave just rebooting the board.here's the funny thing about micro waves sometimes the part you're gonna change is almost the same price as a new micro wave so i would first check how much the board is,i went on sears and they have the board for 115.00 repair clinic for 235 part number WPW10216347 they don't make this model anymore but you can get a stainless micro for around 290 to 300 dollars and if you buy the same brand all you should have to do is remove the bolts up above that hold it in place and remove the micro wave and the same brand should mount the same way so you won't have to drill new holes or replace the back metal panel.if i were you i would replace the unit instead of the board repair clinic shows most of the parts for this model out of stock so it might be a while before you can get any parts for this model but this is up to you.good luck with your micro wave.one more thing when you were in there did you see alot of grease,this is usually the cause of no heat,the grease from cooking on the stove top gets into the micro wave and on the mag tube and damages it,if there was grease in there i would just replace the unit
Dec 15, 2017 | Whirlpool WMH2175XVS Stainless Steel 1000...
Micro wave simply quit. How an I check to see if
The fuse is located inside the microwave. You will need to remove the front panel to get to it. It will be located on the black power wire inside the microwave and installed inline. Make sure that the microwwave is unplugged before removing the front panel. Once you locate the fuse inside you will need to remove it and test it with a continuity tester to see if it is blown. If it is make sure you replace the fuse with the same amp rating you found. If the new fuse blows again then there is an electrical short somewhere inside the microwave.
Dec 24, 2009 | Emerson MW8778 Microwave Oven
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
Oven appears to function normally but doesn't cook at all.
With micro waves, this could be a number of things. They are hard to diagnose using this forum but I'll try. There are three things you can check. One being the thermal fuse. On some models, when it goes bad it put some things out. with others it puts every thing out.
if it's good, check the mag tube (Magnatron). Most of the time, it will be burned on the end if it's bad. tube. The last thing would be the fuse. It is made of ceramic and is a 20amp. It looks like a old round car fuse but it's not. It's made just for micro waves. Honestly, if the thermal fuse and the round 20 amp fuse is not the problem, you may be able to replace the micro wave cheaper than replacing the parts.
Thermal fuse $28.99.
Round 20amp fuse $1.53
Transformer $100.00.
Mag tube $87.00
Capacitor $45.00
Go to www.appliancepartspro.com and enter your model number. This will pull up every part in the micro wave and their prices. Then you will ba able to decide if you want to replace the parts. With yours being one that's built-in over the stove. These cost more and are worth putting more into. If I can help any more comment back and I'll do what I can.
Please rate solution
Sep 07, 2009 | Maytag MMV5186A Microwave Oven
Repair an Amana microwave
My amana micro just went dead. No lights nothing ,almost like a fuse blew.Its an over the stove model . The outlet works fine.#mvh210w
Dec 21, 2007 | Amana AMC6158B 1000 Watts Convection /...
Frigidaire GLMB209D Microwave Oven Logo
104 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
