Question about Whirlpool Dryers
My Whirlpool Duet dryer has 4 beeps 4 times and then stops drying... This started after I replaced the belt and I cannot figure out what the 4 beeps mean... I googled it and cannot find it anywhere
SOURCE:
  • 1073 Answers
SOURCE: can't figure how to use
insert the drying rack into the dryer with the wire end resting aginst the rear wall of the dryer and the frount of the rack over top of the lint filter
Posted on Apr 30, 2008
aborcass
  • 2651 Answers
SOURCE: Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
Posted on Oct 26, 2008
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
SOURCE: my whirlpool duet dryer will not start. Power
Mine isn't stacked and I had the same problem. My husband and I just bought ours last week. I had to close the door and then press on the top of the door to hear another click and it then would start the cycle. I don't know if this is correct or not. I have searched whirlpool web site and not found mention of this. I am calling the department store we purchased ours from to see if this is normal. Hope this helps!
Posted on Mar 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Steam Dryer Beeping
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#$%^
Posted on Sep 30, 2010
Dryer won't start, push the start button it just beeps
It is possible you have a broken drum belt. You may need to call a qualified service man as changing a belt can be tricky.
Oct 01, 2015 | Whirlpool Duet WED9550WW 27" Electric...
I have a Whirlpool AccuDry Dry (Model LGQ8858JQ2). It will start fine, but will stop shortly into the dry cycle and beep three times. The drum turns and I checked the belt. The timer continues..but at
I think that it's a door switch error.
Open the door and locate the door switch. Exercise the switch with your finger about twenty times then try the dryer again. You may have to replace the door switch.
Check youtube for help videos on replacing the door switch.
Nov 05, 2014 | Whirlpool Dryers
Everything appears normal,,, when we hit start it beeps however it does not start, there is not an error code,, the time of dry remains in the display
Just ran into the same problem with our Duet electrical dryer, also the courtesy light blew out when this all happened. Has anyone given you repair/ reset ideas?
May 08, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The dryer won't start, when I push the start button is just beeps. I checked the door and it's shut and nothing is in the way. It was working a few hours ago. We had a bump in the power earlier today...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have had my whirlpool front loading dryer for about 5 years. It worked fine for a couple of loads and then when I started to dry the next load, it won't come on. It just beeps, checked the breaker,...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
DUET DRYER MODEL NO. GEW9200LW1. DRYER WON'T SPIN. CONTROL PANEL LIGHTS UP, TIMED DRYING SELECTED, HOLD START BUTTON DOWN AND NOTHING HAPPENS. ALL I HEAR IS A CLICKING NOISE AT LEFT REAR OF DRYER. IT...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Oct 11, 2010 | Whirlpool Dryers
Whirlpool duet gas dryer. was working fine now all light and time amount work but will not start and beeps 3 times
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
May 17, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a Duet dry that is sqeaking very loudly for about 4-5 minutest and then quiets down. Do you have any suggestions?
It is most likely the belt slipping, just like a cars fan-belt. It most likely needs replacing or tightening.
Apr 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dear Customer
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
