Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
Lines and colors 60 projection hd ready
Blue and red colors are more dominate on different channels.horizontal lines (like in letter box) pic tilts down & to the left
Your rich buy a new one hay
Posted on Dec 22, 2007
Colors are way off. Too much orange, colors eratic.
You need a convergence kit. Search Goo*le and will have a kit make for your specific tv.
Replace with the kit and your colors will be better than ever!
Thank you!
Jun 14, 2011 | Hitachi 57F510 57" Rear Projection...
If your talikng about alignment that is done through the Convergence feature. If its the color balance youre refering too its most likley indicating that the CRT coolant needs replacment as that will make the red Tube dominate and wash out both blue and green colors untill they appear dull and dim.
Feb 17, 2011 | Philips 60PP9352 60" Rear Projection...
Where are the convergence chips located on my 60PP9202 for the red
There are 2 Convergence Chips: 1 for Horizontal (it includes Red, Green and Blue Convergence channels) and 1 for Vertical (it includes Red, Green and Blue Convergence channels). Horizontal Convergence Chip is 7044 and Vertical convergence Chip is 7045 (both STK392-120). They are fixed in same "big" Heat Sink, with a 2 metal black clips, from Video Inputs board side.
Oct 19, 2009 | Philips 60PP9202 60" Rear Projection...
Cannot adjust red multi point
Unit appears to have poor convergence due to:
1. cross hatch appears tilted
2. one color (or more) being larger than the others.
The yoke or yokes may have:
(1) rotated slightly or
(2) slipped down during transport.
Loosen a yoke and lower to inspect the tape. If black tape is present remove it from under all yokes (white tape or no tape is OK). Slide yoke or yokes up tight against the CRT and tighten to prevent slipping or rotation. Precede with
alignments and or convergence as necessary.
Jul 29, 2009 | Philips 60PP9202 60" Rear Projection...
Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
Jul 25, 2009 | Philips 60PP9202 60" Rear Projection...
Connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Jun 06, 2009 | Philips 60PW9363 60" Rear Projection...
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
