Question about Emerson Televison & Video
Code for Emerson TV DVD combo - Emerson Televison & Video
SOURCE:
Gigatech
  • 259 Answers
SOURCE: emerson remote for emerson tv/vcr combo
Emerson TV codes 0154, 0236, 0463, 0180, 0178,
0171, 0623
Emerson TV VCR Combos 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Posted on Dec 12, 2007
freetek
  • 5569 Answers
SOURCE: ld200em8 universal remote code
Check DTV's site to see if they have updated the code lists for your respective remotes.
I have two newer sets for which there are no codes too.
Seems like the term 'multibrand' remote might be more accurate than the common 'universal.'
Posted on Aug 27, 2008
SOURCE: TV/DVD CODE for Emerson LD200EM8 for direct tv remote
http://www.remotes.com/store/emerson/ld200em8.html
Posted on Nov 11, 2008
dragonsthatk
  • 547 Answers
SOURCE: Need code for Emerson TV,DVD,VCR Combo
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Posted on Feb 12, 2009
called comcast
Posted on May 28, 2009
What are the codes for emerson combo t.v. d.v.d.
Found this online. This is a "One For All" URC 8820.
The exact setup code is TV 1886. The newer version 8820N has this code. The older 8820B00 does not have this code, or anything similar. The only UEI remotes with TV 1886 are the OFA URC-8820N, 10820N, and RCA RCRP05B.
BTW, from hifi-remote.com, the TV/DVD combo is made by Funai, and uses NEC1 132.224.
Sylvania/Emerson/Funai : Remote Part# NF602UD
TV/DVD Combo's: FXV8266, LD155SL8, LD200EM8, LD200SL8
May 28, 2015 | Emerson Televison & Video
Emerson tv with dvd as well. need a new remote
Setup code for Emerson TV/DVD combo is: 0456
Select a remote control, which have this setup code for TV/DVD code list. You can refer for it in its code list.
Jun 14, 2012 | Emerson Televison & Video
Emerson tv/DVD combol
Hello
Sorry. There is no setup codes for Emerson TV/DVD combo with URC-3021 remote control. The only one code is there and is for Sylvania TV/DVD combo; and it is [0675]. OK.
Jul 31, 2011 | One For All URC-3021 Remote Control
Please inide code for tv emerson
Hello
You havent specified what type of Emerson combo is yours. Anyway I hereby posts some Emerson combo codes.
TV/VCR
0227 0233 0254 0264
.... 0265 0266 0310 0325 [0039 0252]
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR. Otherwise just the one code operates both the TV and the VCR
TV/DVD combo
0456
TV/VCR/DVD combo
0456 [0458 0227]
DVD/VCR combo
0456 [0458 0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Mar 15, 2011 | Emerson Televison & Video
Feb 12, 2009 | RCA Universal Remote 3 Device Remote...
I don't know if you guys even need this advice anymore, as it's 1-2 years late, but if your universal remote has a VCR setting, the Emerson 13" CRT TV/VCR combo I have operates under that mode.
The code I used was 002. These may also work: 278, 184, 479, 000, 121, 211, 037, 043, 061, 208
Remember, program your remote as if you were setting up a VCR (and NOT a TV). For instance, on my GE universal, I hold the "code search" button down until I get a steady light. I hit VCR, and then I entered 002. Works like a charm.
Mar 25, 2008 | RCA Universal Remote 3 Device Remote...
No code for the Emerson tv, dvd combo, model #LD200EM8
i have a remote and i can't find or program it to my tv combo tv/dvd
Jan 14, 2008 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
