Question about Intel Motherboard
Hooking up Front USB Port I am attempting to hook up the front USB port.I have a EMachines W3052 desktop computer.I am having problems connecting the USB port wires to the Motherboard.I can't seem to figure out which wire goes where.The port has two seperate wires. One has 4 pins the other has 5 pins.The mother board has 2 seperate rows of pins with 5 pins on each of them.I can get the computer to reboot but I can't seem to get the USB port to work properlly.Any help would be great.Thanks
Re: Hooking up Front USB Port I am attempting to hook up...
The red wires go on the side that is not missing a pin.
in this scenario, 4pin goes on top, 5pin on bottom, red wires on left.
in this, 4pin on bottom, 5pin on top, red still on left.
i wont show you the reverse of that because you should understand and i think the formatting on this page will screw it up.
Posted on Jun 11, 2010
  • 94 Answers
I would like to help you with your problem but its hard because I can't see your motherboard right now so what I would like you to do is try to look for the manual of your motherboard for the diagram of it in order for you to know where to hook the cables. If you dont have your manual your can find it in "" click on customer care then click on product support and downloads. Select the model of your PC from the Product Type, Series and Model after that your manual and the drivers for your motherboard will appear and you can download it. I hope this helps.
Posted on Aug 01, 2009
  • 56 Answers
Red, white, green, black.
Red starts at pin 1.
hope that helps
Posted on Nov 28, 2007
2 Suggested Answers
  • 3 Answers
SOURCE: Plugging in a USB port.
You have an A side and B side, or 1 and 2. Starting from pin 1, usually has an arrow pointing to it, the wires should read as follows: 1= A/1 +5vac 2= B/2 +5vac
3= A/1 -D 4= B/2 -D
5= A/1 +D 6= B/2 +D
7= A/1 ground 8= B/2 ground
9= no pin 10= no connection
Posted on Sep 09, 2008
  • 87 Answers
SOURCE: Front USB port is not working
Posted on Apr 22, 2009
0 characters
3 Points
Why am I not getting no signal between computer and monitor. Computer is emachine W3118
According to
eMachines W3118 8512780 eMachines Desktop PC User Guide
Your machine may support more than one monitor and have more than one monitor port. Change the cable connecting the computer and monitor to a different monitor port as the computer may not yet be configured for the port you have plugged the monitor in to.
Jul 06, 2014 | eMachines W3118 Motherboard Replacement...
Dear sir, i have just purchased an asus m4n68-tm mother board with amd athlon ii x2 3.0ghz processor. im facing an strange problem. i have an external 320gb western digital hard disk. the problem is the...
Hi there, It sounds like your problem is that you haven't hooked up your front USB ports to your motherboard. If you open up your computer case, you should notice some cables coming down from the front USB ports. Those cables need to be attached to USB headers on your motherboard. You should check out your motherboards manual to see where the pins for the USB headers are, and then hook up the cable. My guess would be that no USB device works via the front panel, but after hooking up these cables all devices, including your external hard drive, will. If you need more help/clarification, let me know please! Alex
Jun 03, 2011 | ASUS M4N68TM Motherboard
How do i go about hooking up a cruzer usb 2.0 flash drive to my computer
insert the usb flash drive into a usb port can be at the rear and front of a dessktop once inserted you will see a notice on the screen a new device has been added to your computer
hope this helps
Mar 23, 2011 | Motherboards
Usb not working
Check that all the USB ports are turned on in the BIOS setup.
Apr 02, 2009 | PC Chips (M925G) Motherboard
Location firewire input port
There isn't one on the back panel. You must connect the USB/1394 bracket that's included with the board to an empty slot on the rear of the computer and hook up its connectors INSIDE the computer to the appropriate headers on the motherboard: the purple firewire connector would connect to the purple header (DUH!) on the RIGHT in the pic below, it's a DOUBLE firewire header and it's the only place this bracket will fit. The yellow USB connector would go to any open USB header on the board (guess what color...) Very simple, really.
Optionally if your computer case has a built-in firewire port on the FRONT panel, as most do nowadays, you can connect that to the appropriate header on the board using the already-installed cable that's connected to that front firewire port (connect this one to the purple header on the LEFT, it's just a SINGLE firewire port.)
However, this header's pins will NOT match up properly with almost all case's front-panel firewire connectors. You would most likely have to switch around 2 or 3 of the little wires that go into the connector so that it matches the motherboard's pin-out.
It's clearly labled in the manual for the board, and isn't really all that difficult to switch the wires around, but I would recommend just going with the first option and connect the included bracket to the back since it was designed to go with this board and requires no modification.
Nov 01, 2008 | Gigabyte GA-K8NF-9 (890552602964)...
Usb port ceases to work when any device connected to second port
As you stated the device works in one slot but not the other , tells you there is problem with that usb port , don't use those ports , best thing to do is purchase a PCI USB card if you need more USB ports .
Jul 29, 2008 | Gigabyte GA-8I845GVM-RZ Motherboard
Front Side USN dows not work in ASUS M2N MX SE
The front side port may be a "low power" USB port, it may be possible to "power" this if there is the capacity to connect a power cable to the front panel USB adapter, or there may be an aux power socket to plug into on the motherboard.
Nov 04, 2007 | ASUS M2N-MX Motherboard
Front side USB port is not working
On some computers the front usb ports are like a usb hub, they don't have enough power to power up a hard drive.
Media Card Readers
yess use the ports in the back of the computer I had the same problem with my mouse before which was also usb port connection. The reason why I say to hook it up to the back usb ports is that it is built onto the motherboard and therefore it would get recognized alot quicker if you put it there if you find that whatever you have hooked up dont have alot of usb ports buy yourself a usb hub i bought one for 2.00 it does the trick when you are limited to usb connections
Sep 26, 2007 | Intel SYNTAX S651M SIS651 mATX (SYNTAX...
Usb shortage
There's a photo of your motherboard here: You see the part labeled "USB header for two extra USB channels." That is where you'd connect any additional USB ports. When you say you have two ports on the front of the stack, I assume you mean on the front of your computer case? Front mounted USB are handy, and just about standard on most cases. Just connect the cable from them to that connector and you should be ready to go. If you're not sure which way to connect it, just try one - you won't break anything by connecting it backwards (you'll just have to switch it to get them to work).
Aug 30, 2007 | Abit VT6X4 Motherboard
Intel Motherboard Logo
542 people viewed this question
Top Intel Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an Intel Motherboard Expert? Answer questions, earn points and help others
