SOURCE: MITSUBISHI WD-65732 WON'T START UP
IF YOUR LUCKY YOU MAY HAVE A BAD GROUND ON ONE OF YOUR VISUAL INPUT CABLES.TRY ,THE COAX,THEN THE YELLOW 480,THEN THE RGB 1080 AND OR THE DVI.SEE IF YOU CAN AT LEAST GET AUDIO GOING ,IF NOT ,THE REPAIR DUDE WILL START WITH YOUR CAPS ,SOUNDS LIKE THE FIRST ON YOUR STARTER IS OK BUT THERE IS OTHERS THAT START YOUR GUNS (VISUAL) AND THEN THERE IS OTHERS THAt kick on your transformer audio.I hope for your sake
you have a short in a audio or vid and its stoping you from cooking somthing.,Use your nose and touch ,look for a new or old fire ,if you see a punch of circuits laying horzontal and smell theres a good change there connectrs melted and the weightt of the cap or resistor,or transistor bent the soft melting metal. FIRST CHECK YOUR WIRES IF YOU HAVE JUST ONE LITTLE THREAD CROSSING IN TO THE OTHER SIDE YOU MY AS WELL BRING SID BARRETT BACK WITH FLOYD .A LOT OF REPAIR MEN DONT LIKE WORKING ON THESE MONSTERS YOU WILL HAVE TO HAVE SOMTHING MORE THEN BEER AND OR MONEY PERHAPS ONE OF YOUR CHILDERN MAY DO IT.
FIND SOMONE CRAZY ENOUGH TO WORK ON IT.
SOURCE: just replaced the lamp on my mitsubishi wd-65732 2
if you used an OEM lamp rather than an original ,it may have gone out. The more expensive original bulbs last longer
SOURCE: I have a WD-65732. The brightness level is very
Howdy,
I suspect a bad lamp part # 915P020010. When you order it from factory it will give you detail information on how to install and handle.
Good Luck, Big Irish.
SOURCE: WD-65732 has audio but no picture. Sound like
Replace Lamp Call Mats Electronics 1-800-628-1118
