Question about Kenmore Dryers
My Kenmore dryer is not heating and it did show a F01 error code 1 time. My research shows that it is a control board issue.I have not seen the code anymore. Could it be something else?
See if voltage to heating element if yes bad element if no bad board or fuse
SOURCE:
  • 146 Answers
SOURCE: kenmore dryer 417.84072300
Check you circuit breaker. Even if it doesn't look tripped reset it anyhow. This is a power interrupt code.
Posted on Dec 22, 2007
SOURCE: KENMORE ELITE OASIS HE CANYON CAPACITY DRYER
I have the same problem. Started a few days ago. My model number is 67086. How can I fix this? I have 2 year old twins and I'm concerned about the safety of this machine.
Posted on Nov 25, 2008
TheMobilian
  • 8220 Answers
SOURCE: Frigidaire Dryer only runs on "low Heat" setting
Mexitronics
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 20, 2009
mgprice
  • 744 Answers
SOURCE: Washer won't start. Error code f01 shows.
Hi F1 means your CCU is bad and needs to be replaced sorry :( If you have any other questions please feel free to comment again. Mike e63dqt.jpg
Posted on Nov 19, 2009
blueextc3221
  • 15935 Answers
SOURCE: Our Kenmore Elite he5 steam dryer has an error
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Elite he3. What does code f01 indicate?
Be sure to unplug the washer before accessing internal components. When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time. Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer. Reassemble and test the washer.
Error code on dryer F01 Kenmore Elite HE3 Dryer
Nov 19, 2015 | Kenmore Dryers
My kenmore dryer he2 is showing F-01
F01 is failed main control board.
Sometimes, however, it's caused by a power surge. If unplugging it for five minutes and plugging it back in doesn't clear out the F01, then you need a new control board
Oct 22, 2014 | Kenmore Dryers
MAYTAG 3000 F01 CODE
It's probably a weak or failed component on the board. It's a common issue on those machines and the Whirlpool Duets. It's usually burned at the motor relay or heater relay.
F01 error code flashes when there is a primary control failure.
The only thing which will solve an F01 error code is a new machine control board. These is a catastrophic control board failure. Nothing can correct it. The part number you require is W10205977.
Dec 17, 2013 | Maytag Dryers
MAYTAG EPICZ DRYER ERROR CODE F-01
F01 means the main control board or "micro computer" has detected an internal short. Unfortunately, the only way to correct this issue is to replace the control board itself. It's under the top panel in the front right corner.
Dec 05, 2013 | Dryers
Has an f01 error
The error code f01 indicates the primary control board failure. Before you replace that board I suggest that you unplug the dryer for 2 minutes then see if the error come back. If it does replace the board part number W10110641.
May 13, 2012 | Kenmore HE5 Electric Dryer
Model# 11087721700, with f01 error fix
82822 / 82824 / 82826 Electric Dryer: kenmore HE2 electric dryer, beeps and all display ...
May 17, 2010 | Kenmore 82822 Electric Dryer
Maytag Bravos Steam dryer that reads service error code F1
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Jun 30, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
50 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
