Check the PC drum,if dirty clean.Has toner spilled from the I/C inside of the copier?Clean.Is the PC drum charge voltage terminal in good condition?Check and change if necesary.Is the grid voltage terminal in good condition?Check or change if necessary.Are the fusing rollers dirty with foreign matter?Clean or change.Clean the mirrors,lens and original glass.
Was this helpful?
Yes
No
Popular Solutions for Canon imageRUNNER 2200 Black
change do you tell me further explanation in my counrty i have some engineers if send me more...
(More)
change do you tell me further explanation in my counrty i have some engineers if send me more instruction then i will do how you explained the problem thanks
I have a Canon 210s / F139800 that is connected to the local network but I cannot access the printer...
(More)
I have a Canon 210s / F139800 that is connected to the local network but I cannot access the printer through the network. Any suggestions on how to configure the copier/fax/printer to allow access / verify that access is available?
It displays screen to turn off and back on. Error code E00012-002 is there anything i can do to fix...
(More)
It displays screen to turn off and back on. Error code E00012-002 is there anything i can do to fix this?
