Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Blue screen... When I turn on my tv all I get is a blue screen with no sound or video. I tried doing a reset and checking settings but it still does not respond.
  • John Zauner Sep 09, 2008
    I have a blue screen of two shades no sound and TV indictes no signal. I have tried reset numerous times.
  • 1,153 Answers
Do self diagnosis test at
Posted on Nov 29, 2007
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
I am getting a blue screen whenever i turn on my ps3. Ive tried resetting the system several times and can not find the solution. Audio works just a blue screen on the t.v.
You said the sound works but you get a blue screen on the TV, check your TV if it is set properly.
Make sure the Input is correct on the TV to shoe the Video coming from the console and check if the cable connections are properly connected to the TV and the console video output and input.
Also try it on a different TV to see if the issues is with the TV or the Console itself if on a different TV and the issue is still the same the issue is the Video output from the console but to check further more try a different cable, borrow one or maybe buy a new one just to see and eliminate possible causes of the Blue screen issue.
I hope this helps.
Aug 01, 2011 | Sony Playstation 3 (PS3) Console
My sanyo 42 inch plasma has a blue screen, i can hear the sound on the tv but screen remains blue. can u help please
Be sure your channel settings are correct and that you have proper orientation of the hook up cables. See if your remote has a video-mute if so turn it off...a video-mute will produce a blue or black screen. To be sure its not the tuner that's enter the menu screen if you can see the menu then the tuner is ok this means the down-stream video is functioning. Be sure to have all your input devices set to the correct output ports. If all check good and still blue screen then the logic section is not processing video codecs and needs servicing.
Oct 18, 2010 | Sanyo 42 in. LCD TV
I get sound but no picture
If the screen went dark blue, this is the way that sets mute the video to protect the tube. However If the screen is very bright blue with possibly blue lines going through the screen, either the blue gun in the CRT has failed which is unusual but can happen or the driver transistor/IC which drives the blue gun has gone short circuit. If you know how to use a meter, you can perform a comparison check by comparing say the red O/P TX with the blue O/P TX. Ian
Jul 23, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
Mitsubishi ws65613 no picture or sound, blue screen only
Good day, Bgchzy;
This model is known for the tubes leaking fluid, glucose, on the PCB. Check the front of the chassis for said fluid, it may be only a drop, so look closely.
To fix, after TV has no power, try cleaning the board with cleaner and brush, let dry. I suspect this because of multi unrelated problems.
Jun 13, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Olevia T.V problen
Try selecting a different input, or checking the device which you are receiving the signal from. A blue screen typically indicates that there is no signal.
Mar 16, 2008 | Olevia LT37HVS 37 in. LCD HDTV
if you get a blue screen than your lamp is working fine. blue screen is considered "video mute" it display that blue if the tv thinks there is no video. try to reset the tv by pressing - menu 123 then reset to system defaults.
Feb 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
RCA Truflat no picture
problem is in your tv. this is due to blue catode circuit failure. please get it check 1 loose contact in blue cathode crt. 2 loose in crt base. 3 supply to blue video ckt.& transistor itself 4 check blue video ckt components. 5 check blue signal coming to blue video. 6 connector loose. 7 processor ic.
Sep 28, 2007 | RCA TruFlat 27F520T 27" TV
No picture but has sound
Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
Aug 14, 2006 | Zenith DVB312 DVD Player
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
