Question about Bosch Washing Machines
Hi...I have a bosch exxcel 7/4 washing machine and I have put a load of clothes, the program finished and when I wanted to open the door to take the clothes it does not open. I tried everything that I could find online and it did not work
2 Suggested Answers
SOURCE:
  • 135 Answers
SOURCE: bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Posted on Nov 22, 2008
Bosch exxcel 7 have E43 code flashing I can open the door ok and washing Is wet any clues?
drum motor does - REMANENT ERROR - speed sensor is broken - Reset error with activating Normal mode not rotate - washing program is aborted - drum is blocked by laundry test mode Pos.3 Motor - door is unlocked, if possible - motor is blocked - check control - operator control actions are blocked - control is broken - the current indication is frozen ? Triac is broken
Feb 13, 2016 | Bosch Washing Machines
How do you remove the unlock on Exxcel 7 VarioPerfect washing machine?
Aug 13, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
Bosch EXXCEL 1400s. Clothes have a horrible damp smell when they come out of the washing machine. have clean and washed out all pipes but sill a damp smell inside machine. What is wrong with it? So bad...
yes,,,,,1 coup of soda crytal
1 coup of any vinegar
1 coup of diswasher salt
put it on 90 degree empty wash..........and see the result.....
my name is khan.
Apr 06, 2011 | Bosch Exxcel WFX 145S Front Load Washer
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is sironsheik@hotmail.com
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
Bosch washing machine won't drain and the door won't open.
Nov 22, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Washing Machine Smell
.I would try running some washer magic through it first. also when you finish a load a clothes leave the door open for a while to air unit out.Your unit is probally smelling moldy after each wash, leave door open to air out the tub You can get washer magic at your local appliance parts store.
Dec 01, 2007 | Washing Machines
Washing Machines Logo
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
