Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer shuts off
My dryer is only about 3 years old. For several months now, it has been shutting off before the dry cycle is complete then the timer will just quickly go to the end. We restart it several times, choose a different drying cycle...sometimes it works, sometimes it doesn't.
  • 35 Answers
If the venting is clogged this will happen. And that is a good thing because it is a safety measure built in to prevent fires. There is a thermostat that can tell when your dryer is over-heating,(usually caused by clogged venting by lint) and this devise tells the heating element to turn off so as not to create a fire. Clean out venting, inspect thermostats and element, replace if neccesary. You may only have to clean out the venting.
Posted on Dec 09, 2007
    Sergeant:
    Champion:
  • 362 Answers
It sounds like the time has gone bad on you, you will have to replace it.
2 Suggested Answers
catriver
  • 878 Answers
SOURCE: Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
Posted on Feb 19, 2007
Motor on kenmore elite washer quiet pak ii heavy duty capacity king size wont engage, just hums. and ideas?
Sounds like you motor coupling is gone this happens when over fill washer or place carpets/ bed blankets
Feb 15, 2015 | Kenmore Washing Machines
No heat
I can be several things, but most common is a burned out heating element. This can be tested with an Ohm meter.
Mar 15, 2014 | Kenmore Dryers
Kenmore Elite Heavy Duty King size capacity Quiet Pak 1 dryer doesn't turn on
Check to see if the door switch is working. When you push and release it, it should click. If not, it will need to be replaced.
If the switch is good, then the only other component that would cause that problem is the thermal fuse. If you could post your model number I could direct you to the part you need.
Oct 15, 2012 | Kenmore Dryers
I have a Kenmore Elite Heavy Duty King Size capacity Quiet Pak gas dryer. The model # is 110.76922501 and the Ser # is MTO502806. The problem I am having is that the dryer sometimes does not start when...
the push to start switch holding coil is getting weak and can no longer either make contact or drop out shutting down the unit,there is a coil that energizes to hold the switch on and when the contacts or coil get weak the unit either wont start or start and drop out/quit,you can test this switch by bypassing it and if unit keeps running the switch is definitely bad then the unit is a whirlpool produced for kenmore by the 110# you provided so you need to order a switch either thru whirlpool or sears
Aug 22, 2011 | Kenmore Dryers
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
Dryer doesn't work when I want it to
do you mean you changed out the dryer and the same thing is happening?if so it's not the dryer,either your vent line is clogged with lint and the dryer is cutting out from over heating and coming back on when it cools down or you have an electrical problem because there is no way your gonna have that same problem on two dryers,try running it with the vent line removed from the back of the dryer let me know about this
Nov 04, 2009 | Kenmore Dryers
Feb 18, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
725 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
