Question about JVC GR-D250 Mini DV Digital Camcorder
Nothing pops out
So I have a firewire cable and i cant get it to work. I plug in my camera to my computer and nothing pops out.
  • 456 Answers
Re: nothing pops out
First check out the usb plugins that may not have corrupt or not working then check out the input cable circuit of camera try to check all the port in camera with pc then ask me.
Posted on Dec 09, 2007
  • 298 Answers
You may have the cable that comes with the
camcorder has built in filters
and also
When connecting the camcorder to a PC
using a DV cable, make sure to
Connect the DV cable first to the PC, and then
to the camcorder.
Connect the DV cable (plugs) correctly
according to the shape of the DV connector.
p37 of manual
link to manual here:
Posted on Dec 03, 2007
0 characters
3 Points
Step by step instructions to transfer recorded videos from jvc gr-d370u to Pc, please.
First, you need a Firewire connection (also called IEEE 1394). Most of PC computers don't have it, including mine. I bought a cheap Firewire card and installed it into an empty PCI slot, costed about $15.
I hope you don't have the USB cable and the firewire cable plugged into your computer at the same time. That can break things.
With the firewire cable plugged into the DV port of the camcorder and the firewire port of the computer and the camcorder is in Play mode (and plugged into the wall AC power with the power adapter), are you saying that when you launch MovieMaker and "Capture", the video camera is not recognized?
There are only two conditions that can cause this:
1) The firewire400 port on the computer is not working properly (how do you know it is working?). If you are using Vista Home Basic, chances are good that the IEEE1394a firewire port drivers were never loaded... so, that will be your first step. Get that port working and you'll be ready to go.
2) The DV port on the camcorder is not working properly. This could be for several reasons, but lets hope the DV port was not fried if you ever had the USB and firewire connections to your computer at the same time... Reset the camcorder to factory defaults by disconnecting all cables, removing the rechargeable battery and removing the little date/time button battery inside the camcorder. Wait for about 20 minutes. Put the button battery back in, then put the rechargeable battery back on. Set the date and time. Connect the firewire cable to the DV port, connect the AC power adapter to the wall, connect the other side of the firewire cable to the firewire port on the computer, launch MovieMaker - will it "Capture" from the video tape?
Anyone you know nearby with an Apple Macintosh and iMovieHD? You will need a 4-pin to 6-pin firewire cable and the AC power adapter. If it works with the Mac, we know it is not the camcorder's DV port. If it does not work, chances are good the camcorder's firewire port is bad.
Hope this was helpful?
Jan 30, 2011 | JVC GR D370US camcorder Mini DV
Cannot connect to Computer
Turn off computer. Turn ON computer and immediately hold down Apple+option+p+r. after 4 chimes let go. You are going to be using the Firewire cable. once the camera is on and plugged into computer go to : apple> about this mac> more info click on Firewire. on the right hand side you should see your camera. Now if you don't its either the Firewire port on camera or the cable it self. to further isolate. Get your older computer. leave off. plug the firewire cable into both computers. Now the older computer that is turned off. TURN ON and immediately hold down the " T " on keyboard. ON the polder mac, your screen with have like a "Y" icon.. its a Firewire icon. Now look on the other computers desktop, do you see a yellow or blue hard drive on desktop. IF you do.. ITS your camera because we just tested your cable and both ports and they are working. Now try the USB cable and see if its detected by computer by going back to Apple system profiler and see if the computer is detecting it
Mar 24, 2009 | Sony Handycam DCR-TRV18E Mini DV Digital...
My samsung sc-d363 wont upload
you have to use a firewire cable to upload to computer! I had the same problem! Good luck
Jan 09, 2009 | Samsung SC-D363 Mini DV Digital Camcorder
Video camera to comp.
Try this.
Check if it has the firewire port. If so, you can get a 4 pin firewire cable and connect to the PC.
Switch on the Cam.
Open Windows Movie Maker and import video from device.
4 pin firewire would look like this:
You can use the Movie maker to burn it to the Disk
Dec 20, 2008 | JVC Everio GZ-MG360 HDD Camcorder
Transferring camcoder to computer form
Had same problem...although manual states you can transfer via USB, it doesn't work and won't no matter how many drivers you find. What does work is a Firewire cables. You have three options but I only have tried and proven one. Options:
1. 4-Pin to 4-Pin Firewire transfer cable. The camera has a Firewire port directly below the AC Power adaptor port. This worked fine pulling the video to my PC using Windows Media Transfer. No drivers least for Vista. As soon as I plugged in the camera, a window opened asking what actions I wanted to take. Only my HP Laptop equipped with 4-Pin Firewire.
2. 4-Pin (Camera) to 6-Pin Firewire (PC). My Laptop or Desktop not equipped.
3. 4-Pin Firewire (Camera) to USB (PC). Might work but since I couldn't pull data through Camera USB, didn't want to invest in this cable configuration.
Solution in future is buy a bunch of SD Media cards (Not SD-HC) and stop using tape. Transfer direct to PC from SD Card.
Nov 11, 2008 | JVC GR-D271U Camcorder
Cant detect camera on dv video recording transfers.
Hi, I hope the camera you are talking about is ZR200 Mini DV.
As per its specifications. It has a firewire/DV port.
Therefore, follow these steps. I assume you are using this cable.
I am not sure how you used the firewire cable before.
So, try this. Connect one end of the cable to computer and other to the camera. Switch on the camera and keep it in play/ edit mode (not in shooting mode).
When you connect the other end to the computer,  There should be a popup asking you what to do.
If there is no popup,  Open Windows Movie maker and import video from device. You should see the camera in it.
Hope it works.
Sep 24, 2008 | Canon ZR200 Mini DV Digital Camcorder
Dvcam dsr 45 firewire problem
if you can use your computer and cable firewire for other device. it means that your ic firewire in your dsr 45 is defect/broken,if you want to capture without firewire dsr45 , you need video and aodio in card for your computer.note ic firewire easy to defect/ broken if you plug/ uplug it when the device and the cumputer are on.
Aug 26, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Panasonic NV-GS70 lost cd installer
Hi, I purchsed Panasonic NV GS-70 in 2004 and facing the same problem in transferring videos to computer. I tried for firewire cable option as well, but the camcorder does not have a firewire port.
Can anyone suggest what kind of firewire cable to be used for it.
Feb 11, 2008 | Panasonic NV-GS70 Mini DV Digital...
Firewire (i-link) computer does not recognize cam
as far as the camera not being recognized when using firewire, you have to use a genuine, original Sony i-link/firewire cable. for the longest time i couldn't figure out what was wrong with the camera. i tried two different cables and two different computers. finally i took it to a sony service center and had them check it out. when i went to pickup the camera they said there was no problem. i didn't believe them and asked to talk to the technician that worked on the camera. I told him to show me it worked and was recognized. He did indeed, but using a sony cable. when i gave him my cable to try, it didn't work. luckily they were nice enough to let me go without paying the $80 minimum charge for any work, including the diagnostic "plugging in sony cable" check. I then bought an overpriced sony firewire cable for $25 and everything works. Damn sony's proprietary **** (all the sony people i related this story to blamed the bad quality of the cables i had been using)
Sep 29, 2006 | Sony Handycam DCR-HC42 Mini DV Digital...
PLEASE HELP ME! Panasonic firewire connection won't work!
In short, many people have firewire issues such as missing motherboard drivers, or dead firewire ports. You have to show it working on some machine before you know to try to fix your machine. Did you try Movie Maker?
Sep 06, 2005 | Panasonic AG-185 Camcorder
JVC GR-D250 Mini DV Digital Camcorder Logo
73 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Shekar Avadhani
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
