Question about Hobart Food Mixers
Date of manufacture Hobart C-100 mixer #1201733
    Master:
  • 396 Answers
FROM FIXYA
"Just give Hobart a call, and they should be able to help you (if you're in warranty, sometimes even for free!). Their phone number (according to their website, www.hobartcorp.com ) is 1-888-4HOBART (1-888-446-2278) "------
Posted on Apr 01, 2019
SOURCE:
SOURCE: Trying to find gears for an Old Mixer
I have a hobart 10 quart mixer with no attachments. Either I could sell or repair your mixer, or buy your old one. We could replace it with a slightly larger hobart mixer as well.
Tom
Posted on Dec 25, 2007
bigg t
  • 640 Answers
SOURCE: hobart 20 quart mixer
Hi im a service tech for hobart.I cant give service manuals out because i could lose my job but i can step you thru your problem with the mixer,let me know.
Posted on Aug 24, 2008
  • 6 Answers
SOURCE: need to buy a switch for the c-100 hobart mixer?
try www.onesharpstore.com If you don't see what you want e-mail them at www.onesharpstore@comcast.net they may be able to help. worth a try. Harry Oooooooo
Posted on Feb 10, 2009
ricardok45
  • 135 Answers
SOURCE: Hobart A-200 serial # ?
Hi. Your mixer was manufactured in 1967. If you plan on keeping it, take the outer cover off, gently remove the two metal dust caps with a small screwdriver and look into each opening with a good flashlight to determine the quality and amount of grease in the trans. case.
Ideally the grease should almost fill the space with no oil visible. If you need to look further, I suggest that you open up the transmission cover, to determine the condition of the grease that lubricates the transmission. If you find that oil is seperating from the grease. you would do well to remove all of the oil and old grease and replace it with either Shell Darina EP-2, or Chevron FM ALC EP-2 grease. It's a messy job, but it will add years of life to your mixer.
Check the planetary seal, remove, clean and regrease the planetary gearing. With a mixer of this age, you never know if it has ever been serviced since it's manufacture or not. The grease must totaly encapsulate the trans. gears. As the grease breaks down it's level lowers and it leaves some of the upper gears without lubrication, and will result in preventable wear.
Good luck! If you found this solution helpful, please rate it. ricardok45
Posted on Feb 26, 2009
Cuisinexpert
  • 61 Answers
SOURCE: oil leaking from hobart d300 mixer
DEFINITELY contact the manufacturer (Hobart) on that one. Sounds like you're having some sort of an internal problem with it (something might be cracked), and in this situation, the best way to go is to contact the manufacturer rather than try to repair it yourself. If you're still under warranty, and you try to open the machine up to fix it yourself, you could wind up VOIDING the warranty, and if you're out of warranty, most repair places won't touch a machine that you've messed with already--too much of a liability.
Good luck! :)
Posted on Aug 27, 2009
Trying to find the age of a Hobart Mixer serial number 1569386
Contact hobart directly, they tend to keep a record of machines, and would probably be able to as sit you
Feb 15, 2018 | Hobart Food Mixers
HOW OLD IS MY MIXER
The Hobart A-200 is an 80's product. These first came on the market around 1985. There is no way to date the one you have without examining it.
The best estimate is 25-30 years old.
Sep 22, 2015 | Hobart A200 Stand Mixer
Age of mixer Serial # 11-064-362 A-200
Id contact Hobart. the serial # doesnt use a date code. Hobart Contact Us
Sep 02, 2015 | Hobart Food Mixers
I just bought an old Hobart mixer....All the
www.hobartservice.com enter your zip in "locate an office" it will bring up your local Hobart office.
May 16, 2010 | Hobart D300 Stand Mixer
How old is my H660T mixer
this mixer came out of a pizza hut in illnois, looks like the manufacture date is june 1994, dont forget to vote, hope this helps, monomoy
Dec 16, 2009 | Hobart H600 Stand Mixer
Hobart c-100: how to remove gear shift plate???
parts are almost obsolete for that mixer
Oct 02, 2009 | Hobart A200 Stand Mixer
Are attachments for a KitchenAid K5 compatible with the K55?
That would be incorrect. If the attachment is for a hobart kitchenaid mixer then it will fit all models of kitchenaid mixers including the brand new pro series because the attachment port and drive gear has not been changes since 1925 or 6 when it was first introduce by the Hobart company.
Apr 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Year manufactored
If you call your nearest Hobart Parts place they can tell you. If they refuse this simple request, log on to www.hobartservice.com and look in the discontinued products menu, select Food Machines then Mixers and sift through the files until you find the documentation for serial numbers/dates. The lists are not complete and stop in the late 1980's. If you're lucky, you can find out which plant manufactured it, as the first two digits of the serial number indicate where it was built. The serial numbers are not in code, so it's relatively easy to get a date if you do the math. While you're there, download the manuals for parts and operation. You won't find the service manuals..."Top Secret"! Good Luck! Ricardok45.
Dec 21, 2008 | Hobart N50 Stand Mixer
Univex mixers
Im not bias on my opinion,but from the repairs i do on mixers hobart mixers are far superior than other manufactures.Hobart is over 100 yr old company that started with mixers and their service dept. is good.unlike any mixer out on the market they mirror off of hobart.
Nov 29, 2007 | Univex 250 Watts SRM12 Stand Mixer
sorry my friend but that is a very old mixer and we dont sell them anymore (im a tech for hobart).the only suggestion i have is to find a machine shop in your area and bring them the old gears and see if they can machine them for you.are they broken?whats the problem.
Nov 02, 2007 | Food Mixers
Food Mixers Logo
52 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
Steve Allison
Steve Allison
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
