Try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check timer , thermostats and safety switch on motor (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Make sure the vent (to the outside) is not plugged. This should be cleaned every couple of months. If it isn't that, it sounds like the thermostat.
Hope this helps.
