Magellan Maestro 4250 GPS
Problem for Magellan Maestro 4250 GPS
USB port bad
By cheezeycrack on Aug 06, 2009
Intermittant connectivity with the USB port/charger. Tried two different plugs. Problem is with the receptacle. Searching mouser.com to find replacement. Pin 1 rings to receptacle chassis. Is this right and what part number do I need to get this thing back to charging?
Solution #1
posted on Aug 14, 2009
Not Rated)
palaboy
Rank: Wiz
Rating: 83%, 1248 votes
hi,
Please try to charge your unit using both the AC adapter and the Cigarette Lighter Adapter. If only one fails to work then that accessory needs to be replaced
If both fail to work, then the unit requires repairs, please click here , click on "Support/Repair Request", then login and complete the form for assistance.
hope this helps, thanks for using Fixya!
Was this helpful?
Yes
No
Solution #2
posted on Aug 06, 2009
Not Rated)
imbmetz1
Rank: Guru  GPS  Expert
Rating: 90%, 387 votes
sadly, i havent seen a usb port on a gps that has not ripped the tracers off the board, making a repair, impractical.
have you looked at the board to verifiy it can be repaired, if so, i might be able to lead you in the right direction to aquire 1 ...btw, doesnt this model (4250) also have the standard round female power port?
Was this helpful?
Yes
No
Popular Solutions for Magellan Maestro 4250 GPS
Questions and Unsolved Problems for Magellan Maestro 4250 GPS
Do you recommend Magellan Maestro 4250 GPS?
Answer
Answer
Maestro 3100 will not change locations. I can be in Nashville, tn and it will have the screen on... (More)
Answer
error "failed to write TOC" will not reset
Answer
I have a magellan maestro 4250 and if I plug in power from my car it doesn't show the map, how can I... (More)
Answer
parked at rest area-driving 5 more hours and the receiver showing that my location still at the same... (More)
Answer
my north america map somehow disappeared can you help me re-cooperate it??
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top GPS Device Experts
Top GPS Device Repairmen
in New York, NY
(408) 298-8188
Auto Nav 2000 Plus, Inc can repair most portable...
Auto Nav 2000 Plus  IS YOUR ONE Stop GPS Store
(281) 371-2722
GeoQuip is a "One Stop Trimble Repair...
Gulf Coast GeoQuip
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
