Hi, I've had my 42" LCD for a little over a year, and it when I turn the picture on, it looks like it has lost almost all of it's bright colors. Bright spots in the picture like hair, face, and sky look like they are highlighted in pink and green. At first it happened as the tv had been on for a while, but now it happens immediately. Does anyone know about this problem?
Try replacing your lcd controller. It's the board that actually makes the screen display the picture. Usually you will see the colors getting a little screwy and then the longer you have the tv on the hotter it gets and the worse it gets. I had one that started to look silvery then got worse as it got warmer. For lack of better ways to describe it, it was like you were watching tv on a crazy acid trip. Once you change the controller it should be ok. If that doesn't work 99% chance it's a bad lcd panel. I've seen about 6 of those all with similar issues as you have, they were all brand new tv's and all Sharp Aquos.
Was this helpful?
Yes
No
Popular Solutions for Polaroid FLM-2632 Television
I am having problems connecting my DVD recorder to my Polaroid TV via the component connector as...
(More)
I am having problems connecting my DVD recorder to my Polaroid TV via the component connector as well as a HDMI cable.
i have a coby TF-TV1901 (19"lcd flatscreen).hooked cable up and had picture for 2 seconds then...
(More)
i have a coby TF-TV1901 (19"lcd flatscreen).hooked cable up and had picture for 2 seconds then nothing and i havent had any picture since. its not my cable box because all other tvs work. i brought mine down stairs to try a dif. connection but still nothing. ive done the factory reset and uto search countless times but im at a dead end
TV is about 18 mos old and during last mos have noted a black line forming from top to bottom and...
(More)
TV is about 18 mos old and during last mos have noted a black line forming from top to bottom and the right side of TV almost like when you used to have to Degas you PC monitors Stays in same stop. it there as soon as unit is turned on Thanks for help
