Question about Kyocera Mita FS-1030D Laser Printer
Kyocera Prescribe programming
I am using a Kyocera FS1010 to print ASCII data from a Unix system.
I have written and programmed a macro which I call from one of the "Logical" printers and it works fine (an invoice overlay).
I want to program one of the other logical printers to print reports in compressed mode, so have used the Precribe command
!R! FSET 4S;EXIT;
but this doesn't work.
Do I need to put any other command in to make it work e.g select the font first etc.
  • nalmo Nov 30, 2007
    The PRESCRIBE manual says that you can set any or all of the characteristics using the FSET command.
    My problem is that it works correctly for the logical printer on port 9100, but not on the logical printer on port 9101. My unix system can connect to a network printer directly (IP 192.168.1.20) but to port 9100 only (I can't set port numbers in SCO Open Server/unix); it accesses port 9101 as a remote printer via an XP machine (192.168.1.10) which has printers configured for various ports.
    Sniper:
  • 56 Answers
Hi, I think that You must set parameters for line space,or character space.Also set parameters for margines,L1L2,etc...
have You prescribe manuals? if not, You can download it from Kyocera web site,section downloads.
Posted on Nov 29, 2007
Try to use FRPO commands,but before that print status page and service status page.(Press and hold green button on printer about 10 seconds)
Posted on Nov 30, 2007
Kyocera fs 1028 error pcl xl kernel error operator 0x6b position 938
PCL error is telling you that the printer does not understand the data being sent. Could be a corrupt or incorrect driver, or the program you are printing from is sending corrupt data.
Aug 28, 2015 | Kyocera FS-1028MFP
The logic card of my TallyGenicom 6312L line printer has been repaired. it is not working on Unix OS but working in Windows envirinment. what is the solution?
The solution depends very much on the cause of the problem. I note that you can print from Windows, this indicates the intrface you are using is functioning correctly and it should therefor be possible to print from Unix to the same interface if it is connected to the Unix system. If the printer is connected via a network interface, check the IP address on the printer to ensure it matches the IP address set up for the Unix print queue. Try pinging the printer from Unix. Ensure the EMULATION setting on the printer matches the Device Type selected on Unix. You may need to identify if any data is being sent for Unix perhaps try sending a test text file to the printer. A common cause for printers not printing from Unix is no Carriage Returns or Line Feed commands in the data. Try setting Auto CR to ON in the printer, of this does not work try setting Auto LF to on. If there is still a problem please post the connection method and also any errors or symptoms seen when printing from Unix
Sep 27, 2011 | TallyGenicom 6312 Matrix Printer
What is .sdf file
The .sdf or standard data file is used for storing data in a structured format; uses fields of fixed lengths to store values; can be imported and exported by various database and data analysis programs; commonly used for transferring data between different programs.
Sep 03, 2011 | Oracle 10g Database Standard (ODBSEONUPP0)
Output from Kyocera PRESCRIBE commands?
Did you ever find a solution to this?
Mike
Mar 10, 2010 | Kyocera Mita FS-1030D Laser Printer
Kyocera Mita FS1010 fault
check your user guide... it will explain this error... or contact kyocera customer support...
Jun 25, 2009 | Kyocera Mita FS 1010 Laser Printer
Unix
Improving UNIX server performance NOTES.INI settings Most NOTES.INI settings that affect IBM® Lotus® Domino® server performance apply to all UNIX® platforms.
NSF_Buffer_Pool_Size_MB Many machines that run UNIX have very large amounts of physical RAM. Use the parameters NSF_Buffer_Pool_Size_MB or PercentSysAvailable Resources to control how much memory Domino is allowed to use. Each Domino instance on a UNIX machine can reference a maximum of 4GB of RAM.
Disk and memory requirements When a UNIX system runs Domino server software, the server must have enough disk space for program and data files and enough memory to handle swapping and the number of processes. You can also change several system parameters to improve server performance.
Disk I/O tuning Maintaining multiple file systems for operating system files, swap space, transaction logs, and data improves overall server performance.
Use RAID 0+1 hardware for the disk drives on which the data files reside. Use multiple smaller disk drives instead of a few large disk drives for Domino data. Domino does not perform simple predictable sequential reads; therefore, disable Read Ahead Cache and enable Write Cache.
Keeping swap space on its own separate striped volumes improves server performance at high loads. The transaction logs should always be on the most reliable and highest performing disk subsystem available to the system hosting the Domino server. Transaction logging must be on its own disk drives for improved server restart time, reliability, and availability. The logged transactions are written to disk as fast serial writes to a sequential file that is of configurable size in 4K blocks.
Console and database logging To improve server performance, limit the amount of information that is logged to the log file (LOG.NSF) and the console.
Feb 21, 2009 | Computers & Internet
Kyocera FS1010 first page only half printed
I found this solution. Worked a treat. I took the printer apart and applied felts to the solenoids (the felt normally used for the bottom of cup coasters).
See the Success post in this thread...
http://www.copytechnet.com/forums/kyocera/15980-kyocera-fs1010-delayed-printing-1st-page-2.html#post55451
This manual helped too...
http://www.freeprintermanuals.com/PM/Kyocera%20FS-1010%20Parts%20Manual.pdf
This is the post...
Success
A solution has been found. Thank you to Steveauh (Townsville)
Kyocera in their wisdom have used a foam insulator on the 3 solenoids that disintegrates over time regardless of use.
  1. Open the right side of the printer
  2. Disconnect all connections to engine board
  3. Remove engine board
  4. Remove plastic guard (white)
  5. remove all 3 solenoids
  6. Replace all pads on the solenoids that come up against stops
    Registration Solenoid has 2 pads (1 against the solenoid frame and the other on a stop arm, the others just the frame pad)
  7. Keep thickness to around .4 - .5mm Too thick on register arm will cause early printing.
  8. Reassemble
And that is it. The arms were being magnetically delayed due the metallic contact. It seems to be a regular problem in this chassis FS1000 to FS1030.
Jun 23, 2008 | Kyocera Mita FS 1010 Laser Printer
Mac iBook G4 to print on my Kyocera FS1010
well...you need to get drivers from either apple.com or kyocera.com
Mar 23, 2008 | Office Equipment & Supplies
How to write program for running the DOS,UNIX and LINUK command using C language
Dear Sagarshinde111,
Thank you for your excellent question on how to run all DOS and UNIX commands on a Frigidaire GLTF1670A Front Load Washer using the C programming language. I do not know specifically about washing machines, but there is a version of UNIX which has been ported to toasters that would be a good starting point. NetBSD is a full UNIX operating system written in C, and all the source code is freely available to use and change under the Berkeley License (which basically says, do what ever you like, but don't claim you wrote it). You can download it from netbsd.org. You will also find in NetBSD's excellent package source repositories (pkgsrc) the C source code for both DOS and Linux kernel emulation.
I am sorry that we were not able to help you in time for your class assignment (due the next day!), but perhaps this will help the next student who is given this rather challenging homework.
Mar 17, 2008 | Frigidaire GLTF1670A Front Load Washer
Kyocera Mita FS-1030D Laser Printer Logo
1,930 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
