Question about Refrigerators
Refrigerator humming noise and loss of coolness in freezer.
Our refrigerator is making a Humming Noise that comes on & off about every 5 minutes. Our freezer is cooling off a bit, ice cream is soft and frozen items are sweating. I vacuumed the coils but they looked OK to begin with. I removed the rear panel to inspect and touched the Capacitor & Starter to see if they were vibrating but did not feel anything.
Its a Kenmore side by side model 253.52622200
Whay do you think?
  • 213 Answers
Re: Refrigerator humming noise and loss of coolness in...
The relay overload on the compressor is bad. its a very common problem. replace the relay overload and it will start back up again. ( relay overload is what your calling the starter)
Posted on Nov 27, 2007
  • 24 Answers
Your symptoms are classic. What you are hearing is the starter relay trying to start a warm/hot compressor by supplying it with an extra jolt of electricity, but because of the faulty compressor (or if you are lucky a faulty relay) that's warm (cool ones start more easily often) is refusing to budge into motion and compress the freon. Maytag (the model I have that went through this the past week), I believe, has a five year warranty on the compressors. They did on mine, but unless you have an extended warranty the labor replacing it is not covered and that will be around 2-3 hours worth. This is the price we are paying for our quest for energy efficiency. Compressors are being built so small and light that they fail much more often than grandma's old, old refrigerator that was built like Fort Knox and ran for 45 years, remember? But we're being energy efficient! Thank you environmental extremists! I wish I could send you the repair bill.
Posted on Nov 08, 2009
0 characters
3 Points
Freezer side is making an extremely loud humming sound. Ice maker is working fine. No ice buildup anywhere in the freezer that we can see. Loud humming goes on for a few minutes each hour.
Hey Joanne, I appreciate your inquiry!
Based off my understanding the freezer side of your Frigidaire refrigerator is making a loud humming noise. The humming sound could be coming from your compressor. If the sound is a new development it may be a possible issue with the fan pushing further against the wall. You may need to seek help from a professional technician for proper diagnosis and repair. This will help you from purchasing any unnecessary parts. Hope this information is helpful to you. -Matt
Dec 30, 2015 | Frigidaire FRS23W3A Side by Side...
Hi, My fridge ( 420 ltrs) Top Freezer making constant humming noise ( like a dieasl car engine)like the engine keeps running and try to cool the fridge. 1 year old. When I open the freezer or the...
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Oct 14, 2010 | Samsung Refrigerators
Humming noise. Seems to be coming from the fan.
Your freezer humming noise is likely coming from either the fan motor or the ice maker.
Jun 28, 2010 | KitchenAid KSCS25FKSS Side by Side...
My fan in my freezer makes a humming sound
it;s best to replace the fan / or find why the noise . it will probably stop due to this problem. and you may loose food . noises generaly are the first clues . and like i'v said before . if you can hear it it's running . but if your cant it may have quit . . then not cool and food loss . **** / hope this helped mm / feed back pls .
Jan 16, 2010 | GE Hotpoint Top-Freezer Refrigerator
Freezer makes a humming noise and is not freezing
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
Sep 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Noise high pitch noise from the freezer on my side by side
Hi, Remove the rear inside freezer panel and you will be able to see the evaporator fan motor. The fan motor is what is squeeling.
I hope this helps you. Please let me know if I can assist you further.
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire FRS23H5AS refrigerator - freezer not cold
Humming noise would be your compressor going bad. The noise from the fan is because they are over working to try and keep everything cool
Feb 12, 2009 | Frigidaire FRS23H5AS Side by Side...
Freezer defrosted but refrigerator still works
Sounds like the compressor is not running properly. It will overheat and shut off, then restart after a few minutes when it cools off. Check the coils (on back or under) to make sure they are clean. You can do this with a vacuum, or a can of compressed air from the store.
Dec 31, 2008 | Frigidaire FRS26R4A Side by Side...
Amana refridge
The humming noise is the compressor cycling on the overload protector. By the posted date I would think that you already replaced the refrigerator.
Dec 06, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
1,821 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
