DLP bulb replacement
How to replace bulb?
  • jeff39 Dec 30, 2007
    Just replaced the bulb in my Toshiba 62HM95 and plugged the tv in and all I get on the screen is a "Now Booting" message in the bottom left hand corner. None of the LED lights is lit up on the front panel.
  • 179 Answers
Most manufactures consider the lamp to be a consumable product so the will give you instructions in the box with the new lamp..basicaly,,you unplug the set..remove the lamp cover door,,remove the old lamp,,install the new lamp,,replace the lamp cover door, plug in the set...some companies want you to reset the lamp timer and that info is in the owner manual..get an original lamp and not a generic one..call the manufacturer with you model number and they will most likely sell you one and ship it to you
Posted on Nov 29, 2007
Third time replacing 65" mitsubishi dlp bulb ?
Use Osram or Phillips bulbs
Check for blocked air flow
Always allow TV to complete cool down with plug in wall
Check/Replace ballast
Aug 22, 2016 | Mitsubishi WD-65638 65" DLP HDTV
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
First doesn't turn on, now it does but have NO immages, just sound
I would expect that the bulb has failed.
Toshiba DLP Replacement Lamp Toshiba DLP Bulb Part 1
If you decide to replace bulb I suggest that you replace with the best quality bulb. I found the brightness between good and best bulb was significant. I have ordered from the internet and have had great results.
There are other possible causes of lost video. The bulb is only the most likely.
Good Luck
Jan 29, 2013 | Toshiba 53HX71 53" Rear Projection...
WHY DOESSAMSUNG DLP BULB KEEPS BLOWING
When replacing the bulb, it is will be best to replace the ballast also. Make sure that the bulb is of original replacement part.
Nov 29, 2012 | Samsung DLP HL-P5663W 56" TV
How long do bulbs generally last?
Generally, a DLP bulb lasts about 8,000 hours (if a TV is on 10 hours a day, every day, the bulb will last about two years). A bulb can last longer if it's used less frequently. Typically, a bulb in a DLP TV for household use should last at least three to four years before it starts to flicker and needs to be replaced.
Thanks!
Tim
Oct 02, 2010 | Samsung HL-67A510 67" DLP HDTV
HD70 DLP Projector: after replacing bulb warning message of "replaceme...
You need to reset the light counter. Access through right most menu item. Then arrow down to lamp settings.
May 17, 2010 | Optoma HD70 DLP Projector
HOW DO I CHANGE THE BULB
Remove the center panel, on the front of the TV, next to control buttons. The rest is simple, although you will need a long neck philips screwdriver to get to the bulb once get the housing out.
Apr 02, 2010 | Panasonic PT-60LCX64 Television
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Changing DLP bulb
there is not true schmatic to change a Dlp bulb. It should slide or twist right out of its balast and you should be able to put a new one in the same way.
Thanks
Jul 19, 2009 | Televison & Video
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Televison & Video Logo
914 people viewed this question
Top Televison & Video Experts
