Samsung Digimax S500 Digital Camera Logo
Anonymous Posted on Aug 06, 2009
How do you unlock card locked on a p1000 samsung camera theres nothing in the manual to rectify this
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Samsung Master 102,366 Answers
  • Posted on Feb 23, 2010
Samsung Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443107
Points
622693
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Samsung gtp-1000 network lock solution?
Do you want to unlock your SAMSUNG P1000 from network lock?
You can use unlock code to unlock it...Specify current network and country it's locked now and get the unlock code from the site Mobile-unlocker.com/samsung-p1000/rs2wp9/ and unlock it from service provider lock easily.You can follow the free Unlocking instructions below and unlock it step by step...
SAMSUNG P1000 Unlocking instructions:
Method 1:
1 - Switch ON your Samsung P1000 with a NOT ACCEPTED SIM Card.
2 - Samsung P1000 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung P1000 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung P1000.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung P1000 is locked to.
CODE: Its the unique Unlock Code for your Samsung P1000.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung P1000.
I need the instruction on how to use samsung P1000
If you mean the Samsung P1000 tablet, you may download the manual here.
2helpful
3answers
Samsung galaxy p1000 manual
This is the Samsung Galaxy Tab GT-P1000 Official User Manual available for download. (PDF format, 2.8 MB, 82 pages). See also: Samsung Galaxy Tab P1000 ... store.clintongoveas.com/99-samsung-galaxy-tab-gt-p1000-official-user-manual.html store.clintongoveas.com/99-samsung-galaxy-tab-gt-p1000-official-user-manual.html
went in and checked this site out - hope it helps you
CAMERA SAYS CARD IS LOCKED ON A SAMSUNG P1000 CAMERA
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
There is also a software protection feature on some cameras, but this is used to protect a folder or individual picture from accidental deletion, not the whole memory. You set or release this protection from the camera menus.
If it is not that, then maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. Have you tried formatting the card in the camera? This would be one way of making sure that the camera can cope with the card, and it will also erase anything on the card.
Jan 03, 2011 • Cameras
1helpful
I Have An Puremedia sd Card Abs I Have A Samsung P1000 Camera and when I Try to Take A Picture My Camera Is now saying Card Locked!!! Help
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jul 08, 2010 • Cameras
3helpful
I have got a message saying Card Locked ! so it samsung p1000
remove the memory card ..on the memory card there should be a lock switch slide that one to unlock
Nov 17, 2009 • Cameras
3helpful
2answers
My memory card is locked how do i unlock it?
Pull out memory card from camera. on side of card there is a slide switch. The card should say what way to slide to un lock.
Good Luck
5helpful
2answers
How to unlocked card locked on samsung digital camera P1000
take out the memory card from the camera, look for a tab or a switch at the side push it up and insert the memory card back
Please how can i unlocked card locked on Samsung Digital Camera P1000
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
