Question about HP (5064-6630) Motherboard
No Video Output - HP 6635 Desktop minitower - CPU Intel CELEROM 533Mhz
It happenned just like that,
the last time I was booting the computer,
the video output was displayed on the monitor.
Then I shutdown the computer and reboot, and
I get no more otput on the monitor. It just display a message
in a BLUE BOX saying: "Please check video cable connection".
I tested with an other monitor...same thing exept the message
displayed on the monitor was: "No Signal"
any ideas of what theproblem might be ??
If it is a problem with the onboard video card, what can I do
to have it replace ?? do I change the motherboard or can I
pluggin a PCI or AGP video card ? If I do so, any on board settings I have to change ?
I dont have the motherboard manual !!!!
thanks for your time and help :-)
Francois,
Quebec, Canada
    Champion:
  • 209 Answers
If you have changed the monitor and the same no signal have you noticed a beep sound? or can you see the green and red light in front of cpu? if both of this doesn't light it's power supply and if there are led lights (green&red) lighting but there is a continous beep sound the problem is the on board video card. if a sound short beep, beep the problem is your memory card.
Posted on Nov 27, 2007
CPU upgrade for Compaq SR1220NX Desktop
Here are the CPU specs that will help you find a new CPU for your desktop:
Socket 478 for Intel P4 Williamette and Northwood processors
  • Supports Intel Pentium 4 processor up to 2.8 GHz
  • Supports Intel Celeron processor up to 3.06 GHz (Prescott based Celeron with 533MHz FSB)
Oct 14, 2014 | Computers & Internet
Although much noise pc and did not boot
There's not much info here, but the "noise" bit sounds like either your power supply or hard drive may be bad. Do you get any beep codes at boot? Is there any video appearing at all? What does the noise sound like?
Aug 12, 2014 | HP PROMO DC7800 CONVERTIBLE MINITOWER WITH...
Hi, I buy the HP DC7800 Minitower Dual Core PC and i am suffering a problem which i can't understand what going on. After Every 10 Minitues the Hdd Light is showing that hard is so busy and then pc...
It is not a hard disk issue. It may be possible that your CPU is overheating and the BIOS restarts your computer for safety reasons.
You should open the tower and clean the inside of it. Unplug the cooler from the processor, clean the fan od the cooler, install new cooling paste on the processor and put them back.
It should work perfectly.
N.B: Do not change the BIOS settings.
If you need further assistance, leave a comment.
Cheers
Jun 08, 2010 | HP PROMO DC7800 CONVERTIBLE MINITOWER WITH...
Installed a new e5300 2.6ghz dual core cpu on my hp dc7600 CMT to replace my 3.6ghz HT cpu. Both cpus use a lga775 socket with 800fsb. Once installed computer flashed 9 times on front panel red. checked hp...
check the bios settings...if onboard video is enabled or not....
if this does not solve the problem...try to replace the psu...with a good psu from corsair...
this might help...post your further queries
Dec 18, 2009 | HP Compaq dc7600 Convertible Minitower PC...
How to access front side bus settings,on a stock compaq evo d510 minitower,with an intel 845g cpu
I could be wrong, but many of those HP and Compaq models are locked down in the BIOS so that you cannot access/modify those settings. The higher end performance workstations usually allow you to do so, but I would bet this one does not. Sorry for the bad news...
Jul 15, 2009 | Compaq Evo D510 Minitower (Open Box)...
Having a problen installing 1gb ram. unit is 1gb ddr2 dimm 533mhz. computer turns on, shows that it has updated the memory, but does not boot
if the computer states that the memory has been recognised. but fails to boot. it may not be compatable memory for your CPU/Processor. Or system bus. check your previous memory stick, to ensure it,s the same running speed 533mhz. Failing this if your computer does not support this.
check the manufacturers website, to see further details:- Maximum supported memory/Speed et,c.
Systems bios date, and whether an update is available. your only other alternative is to install 2 x 512mb sticks of Ram.
Mike @ compurepair.
Jun 11, 2009 | HP Compaq dc7600 Small Form Factor PC...
Hard to boot
Dear user,
As per your problem i like problem in your motherboard pl checkout with repairer vendor.
Regards,
Ravindra Shah
May 28, 2009 | Intel DQ965GF Motherboard
Computer powers on but does not boot - no videe output.
replace the ram if its bad you wont get any video..if that does not work it is the CPU..
Nov 17, 2008 | HP Pavilion 525c (DD210AR#ABA) PC Desktop
No video output - Desktop HP minitower Pavilion 6635 - cpu Intel Celerom 533Mhz
Try either a pci or AGP card. On most boards, it will recognize the card without changing anything on the board. Does the hard drive and other components power up? Just the video not working ? If so it is probably the chip on the video, if not it could be a board failure.
Nov 27, 2007 | HP (5064-6630) Motherboard
Computers & Internet Logo
158 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
