Question about Maytag Neptune MDG5500AW Gas Dryer
No hot air, no flame, no ignitor
Ingitor doesn't glow red hot
no flame
no hot air
  • 482 Answers
Re: no hot air, no flame, no ignitor - Maytag Neptune MDG5500AW Gas Dryer Dryers
Posted on Nov 27, 2007
0 characters
3 Points
I have a gas dryer and cloths come out wet
Does the dryer get hot? If so check dryer vent.
If it is cold check the gas supply. Next open the lower cover and look to see a red glowing from the ignitor when running. It it comes on and no flame then you probably have a bad gas solenoid. If there is no red glow then it is probably the ignitor.
Hope that helps
Nov 10, 2013 | KitchenAid Clothes Dryer Gas Dryer Ignitor...
Whirlpool dryer(LGQ9557HQ0), ignitor ignites but flame does not light
mounted on top of the gas vavlve is black electrical coils when energized it opens the gas valve,if one of the coils are defective it wont open and let the gas thru,its hard to test the coils so most repairmen just replace them all
Jul 07, 2008 | Whirlpool Dryers
Ignitor glows but short cycles
Ignitors don't "blow flames". But a defective ignitor can glow but not draw enough current to allow the gas valve to open to the burners.
Replace the ignitor. It's the "weakest link" and most likely part to wear out through use in the ignition system.
Sep 19, 2012 | Amana NGD5200TQ Dryer
The igniter glow bar gets bright and hot on the first burn in the drying cycle, however on subsequent urns it doesn't glow bright or long enough to ignite. What's up?
The ignitor is either going to be good or bad. If it fires off it is fine and if it is shutting down then the flame sensor is also working. That tells me your coils are weak and old.
Here is how it works and why I believe you need to get new coils: When the dryer is cool first thing in the morning the initial start up the fuse and control besidethemobilian_2632.jpg
it allow power to the gas assembly, the flame detector/sensor allows power to get to the ignitor and it begins to glow. 1800 degrees is what that baby puts out and at that point the flame sensor bi-metal bends and shuts down the ignitor. The holding coil and secondary coil will then have enough power partially because the ignitor is off and partially because the ignitor is now acting as a thermocouple. If for some reason the gas did not ignite then the ignitor would cool down and shut off the gas. themobilian_2633.jpg
When the temp inside the drum gets to 160f that control beside the fuse shuts off the gas assembly, IF it don't shut down the gas then that fuse melts and shuts down the power to the gas assembly but it doe not shut down the dryer. The fuse is good though because you are getting power to the gas assembly AND the gas assembly is shutting down at 160f. The dryer keeps a tumbling around till the temp in the drum drops to 105f at that time the dryer wants another blast of hot air, trouble is the coils have gotten hot now, the ignitor is doing its thang, the flame sensor is doing its thang, the control is doing its thang. The only thing that ain't happening now is the coils ain't allowing gas to come out. Replace the coils and party on! More here
Jul 18, 2011 | Kenmore 400 6942 Dryer
My Maytag Dryer (Model: DG612 , Series: 05) stopped producing hot air to dry the clothes. I opened the little door on the bottom right hand corner on the front of the machine and noticed that there was no...
Replace the ignitor you broke and check gas valve coils for continuity (they should be in the range of 500 - 2000 Ohm, don't remember exactly). Very likely one of them has failed.
Part numbers for the ignitor (any will do, they're identical):
Part numbers for gas valve coils (complete kit, also identical):
Good luck,
First Choice Appliance
Jun 02, 2010 | Dryers
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
Dryer won't get hot
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Aug 12, 2009 | Dryers
Dryer heating problem
It sounds like an air flow issue. There is a flame sensor on the side of the flame housing. If the venting is not sucking the flame down the tube it will cycle very quickly and never reach the right temp.
Jul 04, 2008 | Amana ALG331RAW Gas Dryer
How do I check to see if the ignitor glow red?
you can remove the front replace the door and check the ingitor .. let me know and I can guide you step by step
Mar 30, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune dryer.
check ingitor see it it glows red hot then check flames sensor and or gas solenoids
Aug 20, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
89 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
