Question about Toshiba Televison & Video
My Toshiba TV makes a really annoying beeping sound when entering an app! I dont know how to remove it! Even if it is on mute!
Go into set up and turn off beep in audio
SOURCE:
SOURCE: Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Posted on Sep 01, 2007
mirran
  • 515 Answers
SOURCE: Cannot turn off alarm.
The machine will not run if the covers /for the coffee grinder, the filter basket and the machine itself) are not properly closed.
It will beep and stop running if it is turned on when one of the covers is open or if one is opened before the end of the cycle. The beeping will stop as soon as the cover is closed.
To start the machine again, press the ON button.
Hope this will help you.
/Mirran
Posted on Aug 12, 2008
  • 125 Answers
SOURCE: my lcd tv makes a humming noise
Try removing all cables going to the TV except the power cord. Power on the TV and press mute. If you have any unwanted noise, then you have a defective TV and since it is new, you should get an exchange. If there is no noise with the A/V cables removed, then you might have hooked the source (cable box/DVD Player) into the wrong inputs of the TV.
Posted on Mar 14, 2009
My 37 inch vizio did the same thing. go to your menu screen on the tv and go sound. My tv has an option to turn speakers on/off. Once I turned my speakers off and the back on again everything worked great. hope I helped! if I did please let me know! youtube.com/xniax1
Posted on Aug 21, 2009
SOURCE: My mic seems to pick up internal noise even when muted
Hi, You can check you the connectios or the mic. remember that the mic is too sensitive, you can adjust it with the nobb on the mic by putting it on o -dB and reduce the highs on your mixer or EQ to reduce hiss sound.
But fisr check the connection properly to see if when muted, is muted properly.
Take care.
Posted on Jun 08, 2010
How can I turn off CC on my SONY 52XBR. I used the Remote control settings and selected off on the cc display, but the cc never turns off. I also used the menu button on the side of the T.V to select
If Closed Captioning is being displayed even though the CC option in the TV menu is set to Off , then it is being produced by another device, such as a cable or satellite set-top box. To remove the Closed Captioning from the TV screen, it must be disabled on the device that is decoding the Closed Captioned signal.
NOTE: Some set-top boxes may automatically display Closed Captioning on the TV screen when the set-top box sound is muted. If this is the case, turn off the Mute function of the set-top box
Oct 31, 2014 | Sony Tv Xbr Bravia Kdl-52xbr5 52 Lcd Tv...
Camera shutter sound comes from my toshiba satellite (window8) My camera is off, i dont know how this sound is coming and is pretty annoying,comes in an interval of of 10 min or even hours. PLease Help
Does this continue even if the sound is turned all the way down, or even muted? If it does, you may have a more serious problem than a camera sound. If not go into your sound application in the control panel and check the system sounds.
Sep 28, 2013 | Toshiba Satellite Computers & Internet
I have a sony ericsson T715 and i want to know how to turn the camera sound off cos its really annoying
There are different alternate camera apps to use instead of the built in camera app. Camera ZOOM FX ($2.99) but there are free apps that you can get as well. In this app press the menu button on your phone/camera and enable and disable shutter sound. If you'd like you can make these apps the default application for the camera as well. https://play.google.com/store/search?q=silent+camera&c=apps
Sep 03, 2012 | Sony Ericsson T715 Cell Phone
Hi there I have a Toshiba HDTV and the sound keeps muting out every now and then. Sometimes it does it a few dozen times in an hour. It sounds like someone hits the mute button for a second and then the...
Try reseting the TV, if still doing the same contact your retailer for a Repair.
To reset Toshiba TV:
Start by pushing the "Menu" button on the remote and going to the "Set-up" option.
Then scroll down to the "Installation" option and press the "Enter" button on the remote.
A new set of options will appear. Highlight "System Status" and click "Enter", then scroll over to "System Information" and press "Enter" again.
Use the left and right arrows to get to "Factory Defaults." Enter your four-digit PIN code or press "0" four times if you haven't set it.
Then select "Yes" and press "Enter" again.
The TV will turn off. Unplug it and then plug it in again. The TV will then be reset.
Apr 25, 2011 | Televison & Video
Default music
I think you computer be running on screen saver options.To rid of problem go to Display Properties on you computer.Get there by going to click start button then click on control panel then click on display.That will take you to display settings,click on screen saver and then on settings. In there there should be a option to mute sound.
This should bring silence
Nov 11, 2009 | ASUS Eee 4G Notebook
I have no sound
go to menu settings and check audio on?
Jul 10, 2009 | Televison & Video
Loud Beep on media control panels volume buttons.
I had the same problem. They sure make it tough for you, don't they? Urgh... it was annoying. Anyway, this is what fixed it for me, a solution from another site:
In the control panel, under sounds. Go to the speaker properties, and then the levels tab and mute the computer beep level.
Source: http://laptopforums.toshiba.com/t5/Keyboards-Touchpads/Satellite-A505-Media-Buttons/m-p/45524;jsessionid=B2EC0FFE986D0F61B1537574ED9EC9AA
Jul 04, 2009 | Computers & Internet
Need help
Make sure that in the set-up, you do not have the feature turned on that makes a beep for each minute in use. This is a common cause.
Check the user guide for details.
Jerry G.
Jun 03, 2008 | Samsung SCH-u340 Cellular Phone
A beep sound is coming from my laptop during booting
what is the beep combination? how many short and how many fast beeps?
Apr 22, 2008 | Computers & Internet
Volumn not working
WHen I hit the mute button again to bring up the volumn the sound remains muted. I have tried all other channels, direct cable and even a dvd player connected. No sound. I unplugged all the boxes and tv and then plugged in again in a attempt to reset what might be wrong. Still no sound. solution 1 while operation mute button has got demaged or pressed more. 2 sound section might have gone defective in tv 3 no supply to sound section 4 or speaker defective or ic got demaged.
Aug 02, 2007 | RCA 27V520T 27" TV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
