Televison & Video Logo
Shaun naidoo Posted on Mar 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi there.. I have a tek L32D10 led tv and theres a small issue. I see double picture and then after it starts to flick around the border of thr screen. It plays fine for a while then starts to show double picture. Whats the best solution?
  • Shaun naidoo Apr 19, 2019
    I had done that.. Even with hdmi,the top of the tv gets really hot and if I touch the cable in the back the picture disappears
Joe Stanton
Level 3:
Genius:
  • Master 1,154 Answers
  • Posted on Mar 26, 2019
Joe Stanton
Master
Level 3:
Genius:
Answers
1154
Questions
5
Helped
315609
Points
3584
Go to Set up menu and disable split screen mode..............
5 Related Answers
A
Anonymous
  • Posted on Dec 09, 2007
SOURCE: Picture issue
It's not the TV it's the source( check settings in your DVD player or cable box
Anonymous
  • 113 Answers
  • Posted on Feb 05, 2008
SOURCE: Cracking noise and flickering screen
Sounds like you have a bad flyback Transformer...Crackling is high voltage leaking. I would quit turning it on and replace the main board in the set if you are good at soldering you can replace the flyback transformer but cost wise it is easier to replace main board. 20" might not even be worth the repair.
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Jul 31, 2008
SOURCE: White border when printing
It is impossible to do borderless printer from a toner based printer because the printer needs a spot on the page to grab it into the fusing section.
If you need to do borderless an ink jet based printer can provide that for you.
Anonymous
  • 29 Answers
  • Posted on Oct 21, 2008
SOURCE: black border around games
Dear milly, so is it clear that this happens on all games or just some? tell me a little more about your system and games you play, I'll try and help. JLS
Anonymous
  • Posted on Jun 01, 2010
SOURCE: Screen resolution change = black border around small screen
Simply press Fn+F7 keys!
How to remove key lock on tek LCD TV L32D10 WITHOUT REMOTE CONTROL
If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs are given.
1helpful
Picture does not extend to screen size
Hi check to c if U have a format button on the remote sounds like picture is in letterbox mode.,.good luck
1helpful
3answers
TEK TV, Model L32D10. What is the code?
0184,0180,0173. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
How do I get a full picture without borders
this sounds like a component issue....time for service repairman to "bench it" at the shop to take a look....
Why does the screen have Black Border around the picture , picture distorted?
There are connectors and circuitry that control the vertical and horizontal picture image generation that need to be at the edges of the screen. The border simply covers these connectors and circuitry so the user cannot see it. Newer models of flat panel TV's solve this problem better to get more picture real-estate to the user. Flat panel TV's are not like the original CRT (cathode-ray) TV's of the past that had borders to conceal a non-linear distortion that occurred at the edges.
Black border with some channels
if you mean the left and right sides of screen, look for a button on remote might be labeled several things, like picture size, aspect etc.. the borders pop up when you go to a non high def channel. some chs put borders all around the picture in those cases you won't be able to get rid of those.
2answers
Black border all around picture
is there a button labeled picture? if so press it (you might have to press it twice before it steps to a new aspect ratio, then once for every different aspect ratio until you get the one you like.
Picture problem
I had the same exact same problem. You can get a repair kit from this site. http:///www.magnavoxhelp.com
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
