Question about Magnavox Televison & Video
I have a magnavox tv model #37mf337b/37....my original remote works...I've tried a universal remote too...pretty sure it's the signal receiver on the tv...any cures for this?
    Genius:
  • 1,153 Answers
Clean the Receiver Window with Windex.........
Posted on Mar 26, 2019
SOURCE:
  • 13 Answers
SOURCE: 32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Posted on Dec 26, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: need a code for a magnavox dvd/vcr com for a jumbo universal remo
7-1-1 and 0-7-1-1 are the Magnavox universals.
Posted on Feb 15, 2009
  • 5 Answers
SOURCE: Need Universal remote code for Magnavox 15MF400T/37
these are the codes associated with Radio Shack's line of remotes:
One for All Universal (Radio Shack)
0054, 0179, 0030, 0020, 0024, 0096, 0186, 0171
And I was also able to find these:
UNIVERSAL REMOTE CONTROL CODE LIST for TVs
MAGNAVOX
002 009 109 118 209 309 402 408 502 508 510 807 914 917
Posted on Feb 26, 2009
  • 4 Answers
SOURCE: remote programming codes
hey, I solved this prob earlier; email me & i'll forward website with Philips codes for CL015; shortribs05@hotmail.com
Pj Aka jd
Posted on Mar 21, 2009
SOURCE: Need a remote code for the tv 37" Sabre LCD Tv Model # lct371bka. RCA Universal remote Model # RCR660
as soon as u bought the universal remote it came with a paper that say a bunch of codes find ur tv model go to set up look were u can put in the code and follow the code exact
Posted on May 24, 2009
Magnavox tv turns off by itself
hello, i don't where you live but there are no analogue signals being broadcasted any more. if your in england you will need a freeview box, some tv will switch off if they are not receiving a signal
regardsshaun
May 11, 2012 | Toymax Magnavox 37MF337B 37 in. LCD TV
MAGNAVOX UNIVERSAL REMOTE
hi have you tried scanning all codes with the remote untill it picks up the correct signal if you have the manual it will tell you how to do this if its possible it will work after searching the codes.
Also what model remote and what make cable box
Mar 29, 2008 | Philips Magnavox Learning Universal Remote
My Phillips HTS3400/37 Home Theater System came with a remote control, as usual, but it just has stoped working.. I've been trying to make it work by replacing the batteries and it still appears to be...
Try this first on the original remote. Insert the batteries backward and make sure that they make contact with the terminals in the remote control(stick a piece of metal in there to make sure all the posts make contact), then take them off and install them correctly and see if it works, it's a long shot but i've had some luck using this method. now, for the question regarding if the new remote will work, well, i couldn't find the correct code for your receiver using the RCA universal control. The receiver brand(Phillips) is not listed so it probably won't. Here's the RCA control's codes. Just copy and paste the link. http://www.remotecodelist.com/remotes/rca/rca_rcu404.html
Aug 23, 2011 | Televison & Video
Sometimes when I turn on my Magnavox 37MF337B tv it emits a very loud squeal and the picture/channel locks up. I cannot turn it off with the remote. I have to unplug it and try again. When it is on though...
you have some bad caps in the mainboard very common on this model the can shaped devices will have a puffed up top i would suggest you have a tech reaplce them they are hard to get out due to the large ground plain on the board you need a good hot iron
Nov 24, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
Magnavox model S1MP6100D/37 I have a large screen
there are 2 stk392-120 chips mounted to a large heat sink. both are bad, also 6.8 ohm 1/4 watt resistors are bad . need ohm meter top check these.
Nov 16, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
Turning off the closed captioning without the remote.
I had the same problem. I got a Philips Magnavox Universal Remote that has a closed captioning button [CC]. Here's a link to the same type:
http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=pd_bbs_1?ie=UTF8&s=electronics&qid=1240350929&sr=8-1
Dec 10, 2008 | Philips 20PT6245 TV
Magnovox: model 37MF337B/37 My Magnovox TV changes channels and even turns on and off by itself... I believe its a defect, but want to ask if this is something that has been heard of or reported. please...
There arethree possibilities that cause this symptom.
1. The buttons on the TV are shorted and must be replaced.
2. The firmware must be upgraded.
3.The main bd is bad and must be replaced.
Nov 11, 2017 | Universal Remote Control DIRECTV Universal...
Televison & Video Logo
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
