Question about RCA Televison & Video
40in RCA with blue lines on right side of screen is it a reset fix or have to take it apart
SOURCE:
tvtek
  • 1284 Answers
SOURCE: BLUE VERTICAL LINE
The address module that is at the bottom of the PDP in that location is the suspect and the cheapest repair. There is usually 3 to 4 modules at the bottom of the PDP and each one addresses information vertically. If it were just one pixe wide then the PDP would be bad.
Posted on Jun 08, 2007
  • 579 Answers
SOURCE: 40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Posted on Jan 06, 2008
SOURCE: Line on screen
if you found out how to fix or what is wrong with tv please let me no shanequinn@tiscali.co.uk
Posted on Jul 15, 2008
  • 185 Answers
SOURCE: red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Posted on Dec 26, 2008
  • 35 Answers
SOURCE: dark spot on the right hand side of the screen
check make sure you didnt put your tv next to some thing that has a magnet in it such as speakers either from a radio or home surround sound system this will cause the problem and if its been sitting beside a magnet for awhile your probably not going to be able to fix it
Posted on Feb 25, 2010
I pulled the screen protector off of My 7inch rca tablet and white, black, blue and brown vertical lines appeared.. How do I fix this, please ?
Seem like when you pull off the protector you have cause flat screen and bd connection to come loose they will have to take it apart to try to fix it
Feb 23, 2016 | RCA Televison & Video
Screen not working lines,color change,olny on blue screen with line down the middle
Let's see if I understand the problem: when you have a blue screen, you see at least one black vertical line in the center, and when you have other material on the screen the same line(s) is yellow (or conversely, you have a blue vertical line that stays on all the time). If I have parsed your complaint correctly, then you have a bad connection in the LCD panel or a bad LCD column driver chip. It is possible that an expert technician can solve a connection problem by "massaging" the connection or taking it apart and reassembling it, but sometimes this only creates more problems.
Replacing a failed LCD panel driver chip requires specialized equipment. Search for "LCD TAB repair" to find a company with the right tools.
Oct 23, 2010 | RCA L22HD31 22 in. LCD HDTV
My rca flat screen tv has a blue tint to the screen that comes and goes. It is like 5 lines of blue on the screen. There is one line that comes down the left side which is not blue. Basically the picture...
Hello:
The symptom you are describing could be one or two things, if it works for a while then starts to act up this coulb be an indication of a bad solder joint. But it may also be the CRT or the picture tube. Try tapping on the sides when it starts to act up while watching the picture to see if it clears when its tapped on. If it does then you have cold solder joints on the main board, this is a easy fix. IF it does'nt then I suggest you contact your store for warranty info to have the CRT replaced or the television exchanged. Since its still under warranty you might as well use it before it expires...
Jun 09, 2010 | RCA TruFlat 27F520T 27" TV
I have an rca DLP 52 with blue line
Howdy,
You have a bad Opitical Engine. It is costly, so call Factory they give you some concession on the part. Make sure you have all the information about the TV like Model Number etc.
Cost of about $900.00 and up.
Good Luck, big IRISH.
Dec 28, 2009 | Televison & Video
RCA D61W20 Projection Television with ITC222 chassis Here is the whole thing , took this machine apart last night the mirror is in good shape cleaned the lenses, picture is much brighter now! However still...
unfotunatly the itc222 has no convergence ics it uses a series of trsansiitors. the fact that u have some areas of the screen clear may mean you need a technician to do a service alignment. when you go into setup does the convergence crosshairs move up and down and side to side on both the blue and red? if they do their may not be a problem with the power board. ONe more thing if you replace this board you will still need a technician to do a service alighnment
Jun 16, 2009 | RCA Televison & Video
RCA HD52W59 Crooked Convergence
Convergence power supply needs to be rebuilt as its no longer available new. You can get the board rebuilt at the following link and its fully guaranteed.
http://servicemanuals.vstore.ca/
Mar 04, 2009 | RCA HD52W59 HDTV Projection Television
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
How to adjust picture on projection tv
i have a 52" rca projection , and the screen looks like this ") (" on the sides can i do something to straiten it back out?
Aug 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
