Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool bake element 9758541 installation assistance.
My bake element went out so I searched online and ordered one. I have unplugged my range and have unscrewed the bake element - now I need assistance in disconnecting the old and connecting the new. Please advise.
  • 447 Answers
Just make sure power is disconnected, pull element forward until wires are exposed, disconnect and reconnect new. make sure terminals fit secure to new element. you may need to gently crimp the spades to make them snug. slide element back into liner pusing wires back through. presto!!!! the new element should now work. it will also smoke
Posted on Nov 27, 2007
Electric range heating elements don't work at all for "bake" function, but "broil" function works (top element) & stovetop works.
The bake (bottom) element has probably burnt out. It's very easy and inexpensive to change them.
First order a new one. Get the range model number and search Google for the element part number. You will get a number of appliance parts suppliers. Check a couple of them for prices and record the part number. (A few suppliers use private part numbers. Most use the manufacturer's part number which will be the one which appears most frequently.)
You could then order from the least expensive supplier, but don't do so. Now search Amazon and eBay for that part number. You will find the part for less than half the price. Order one.
When it arrives, do this:
  1. Unplug the range or make SURE it is turned off.
  2. Remove the old element. It will be held in place with a single Phillips head screw or a hex-head screw. Use the right sized screwdriver or nut driver or socket-wrench as appropriate. The screw will be tight after years of baking. After removing the screw, pull and wiggle the element until it comes unplugged.
  3. Push the new element into the socket and secure it with the screw.
Turn on the oven and let it heat for 5-10 minutes before baking to burn off the bad-smelling coating on the new element.
Mar 02, 2015 | Kitchen Ranges
My whirlpool electric stove not turning on
Make sure it is plugged in and you have power to your house.If everything is dead check your fusebox for blown fuses if you have circuit breakers reset the breaker for the stove by turning it off then back on. If the burners on the top work,but the oven won't you probably have a burned out bake element .To change this turn off power to the stove and unplug remove 2 or 3 screws holding the bake element and remove the wires to the element by loosing the screws on the terminals note sometimes bake elements plug in in this case just unplug. Reverse process to install. Reapply power and test.
Aug 06, 2014 | Whirlpool Stove / Oven / Range Electric...
Wiring that leads to bake element on Electric Range is not long enough to fit through the slot in the back of the oven.
thats why electricians carry long wires and junction boxes of all sorts in their trucks
a solution's is to use a junction connection box and add a new length of wire to the oven side
Apr 16, 2017 | Whirlpool RF262LXS Kitchen Range
IS THE BOTTOM OVEN COIL/ELEMENT TE SAME IN MOST 30" MODELS. MINE JUST WENT OUT. IM HAVING EASTER. NEED REPLACED. model number WHIRLPOOL MOD# TES325MQ 3
All bake elements are not the same. The part # for your bake element is #9758519. Hopefully you can find an appliance parts store in your area. Thay are fairly ease to replace. With the oven UNPLUGGED, Remove the two screws holding the element in and there should only be two wires connected to the element.
I hope this helps you. If I can assist you further, please let me know.
Thanks,
Vic
Apr 23, 2011 | Estate White-on-White TES325MQ Electric...
The baking element isn't working.
You can replace the element. The element should just plug in to the oven. You might have to remove a few bolts that hold the element in place. Get the model number of your range and call your local appliance stores, or order it online. Unplug the old element and plug in the new element.
Apr 28, 2010 | Kenmore 96012 / 96014 / 96019 Electric...
Whirlpool Oven Element
It sounds like you have a bake element that needs to to be replaced. The following link explains how to access and replace one:
http://www.fixya.com/support/r3575810-replacing_the_bake_or_broil_element_in_a
It is common for the bake element to wear out more frequently than the broil element due to the frequency of use. These elements are not interchangeable because of different wattage ratings. You should also check the wiring connections between the element and the Electronic Oven Control (EOC) board. The EOC controls all the oven features. There is a separate relay on the board for each oven feature. It is possible for the bake relay to go bad, or the interconnecting wiring to the element, so you will need to check these items if your existing element checks good.
CAUTION: Make sure you follow all safety precautions and DO NOT attempt to service your range while it is still plugged in. High voltage potentials are still present in the back of the range even when the oven is not on. Always UNPLUG before taking any resistance readings.
Replacement parts can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, or need additional assistance, please post back and let me know. I hope this helps you.
Mar 15, 2010 | Whirlpool RF364 Electric Kitchen Range
Lower heating element will not heat up
check the element for continuity if there is continuty on the element then you need to replace the electronic control. you can also take the two wire from the bake element and move them up to the broiler element and try to turn on the broiler using the bake button this will confirm bad board or element.
make sure to unplug the unit will doing the wire change and then plug it back in
Mar 13, 2010 | Whirlpool RF365 Electric Kitchen Range
Bake element does not heat up
The tech is right if he used his electical tester to test the ERC. Reliable parts at 1-800-666-0313 for your new control, however I strongly recommend you have the technician order it and do the install as the parts houses will not warrantee an electrical part sold to a customer once it is installed. It is warranteed through the technician and he can get another ERC if the new one is bad or he will absorb the loss if he misdiagnosed the repair. Good Luck, Appliance Specialists.
Dec 14, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven does not work, but the range top will?
Hi, Are both the bake and broil elements out?You will need to test the bake element first. Sometimes the element will have bubbles in it where it went bad. UNPLUG the range and remove the 2 screws holding the element in. With an OHM meter, check the element to see if it has continuity. If the test shows an open circuit, replace the element. If the test shows a closed circuit, there could be a bad wire connection, or a problem with the thermostat/clock assembly.
The clock assembly cost is around $100.00.
It might be a good idea to call a repaiarman out to be sure.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 09, 2009 | Ovens
make sure power is off take the 2 screws off element holder inside oven remove 2 screws on element reinstall
Nov 27, 2007 | Kitchen Ranges
Whirlpool Calypso GVW9959K Top Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal De
